B7510 Front end noise? Normal?
/ B7510 Front end noise? Normal? #1
rocklobster
Hello,
I just purchased at 2005 B7510. I noticed that there is a slight sound in the front left tire area when I move forward in 2WD only. It's only there when I move. It almost sounds like something is rubbing. I can't really tell where it's coming from.
It does not occur when I am in 4WD. Also, when in 2WD, it doesn't occur in reverse. Only froward 2WD.
I did not hear it when I looked at the unit before purchasing it. Possibly because I had the RPM up enough to hide the noise.
Is this something normal or should I have the dealer check it out? I'm wondering if this is something free wheeling normally in 2wd?
Thanks,
Joe
/ B7510 Front end noise? Normal? #2
I don't know your specific model, but no, that doesn't sound normal. Was it a used tractor from a dealer? Any warranty? If not, I would jack the front axle up and rock the tire back and forth to see if there's any play. No oil leaks in that area?
/ B7510 Front end noise? Normal? #3
If you have a loader or other way to pick up the front end, rotate the tires by hand and see if you can reproduce the noise. That should help isolate the source. I agree that it is not normal.
/ B7510 Front end noise? Normal? #4
Hello,
Thanks,
Joe
I bought a new B7510HST with the LA302 FEL in 2005 and kept it for 3 years before trading up to a much larger tractor (Mahindra 5525). Never noticed any funny noises from my Bota.
If the noise is bothering you, get it to the dealer for a checkup. If your tractor has a FEL, the previous owner may have caused some front axle damage operating in 4WD while using the FEL.
Good luck.
2016 Hyundai Sonata Sedan (A61574)
2016 Hyundai...
Caterpillar TL1055D (A62177)
Caterpillar...
Generator (A61572)
Generator (A61572)
YANMAR VIO35-6A EXCAVATOR (A63276)
YANMAR VIO35-6A...
2011 CATERPILLAR TH337AG TELESCOPIC FORKLIFT (A64279)
2011 CATERPILLAR...
JOHN DEERE 8360R TRACTOR (A63291)
JOHN DEERE 8360R...
