..another DK 35 making oil
/ ..another DK 35 making oil #1
zukota
Where PA, MD, and DE Meet
DK35 H
Need a bit of help.
It's fuel - oil analysis attached.
I've noticed a lot more smoke at start up in the past few months, and it's always had a lot more fuel knock that I've liked... But I really don't know when this has started.
So I suspect injectors.
Can anybody recommend a shop to send them out to get tested? Any other tests I can make at home?
  • 02 KIOTI-010712-Oil Analysis.pdf
/ ..another DK 35 making oil #2
From what you explain about more smoke at startup and suspect fuel knock, I would go with possible injector tests first. Any Diesel Injection Service shop can inspect, clean, and adjust injectors. Be sure to tell them you want them tested first and report of what they find before repairing them. It has been my experience with a number of injection service centers they will disassemble and clean before testing unless you specify so. If they don't test first you won't know if an injector was causing this problem. If they tell you 1 or more need major repair or replacement, get a price quote first. Most of the time you can get a new complete injector from the dealer at less than the service center charges. Don't know Kioti price but through Bobcat they are about $105 - $115 each.
If and injector is not the problem, next likely culprit is the fuel lift/supply pump. The diaphram may have a small hole in it pumping some fuel into engine block.
/ ..another DK 35 making oil #3
I'd ask around your neighborhood and see where the local excavators, oil supply companies, heavy equipment operators get their diesels serviced, and see if they would do a pop test and whatever else they can to determine if you have a 'pissing' injector or two or a bad injection pump.
Also to help TBN/Kioti 'gurus' help you, please state how many hours, frequency of oil changes, etc., and any other thoughts as to what might have led up to your diluted oil.
/ ..another DK 35 making oil #4
Go ahead and test the injectors but I'd bet on the lift pump (also probably cheapest fix).
/ ..another DK 35 making oil #5
The lift pump sits on the side of the block and could leak fuel into the block. It would be the easier of the two to check and cheapest to replace. But then again you mention more smoke at startup and possible fuel knock so this does seem more like injectors and hopefully only one.
I'd ask around your neighborhood and see where the local excavators, oil supply companies, heavy equipment operators get their diesels serviced, and see if they would do a pop test and whatever else they can to determine if you have a 'pissing' injector or two or a bad injection pump..
Good call. I have to CAT dealers within 15 miles, I suspect they can do it, and I found a shop in town that specializes in diesel injectors. I'll make some phone calls on Monday.
The oil sample has 100 hours on it. 5.5% fuel dilution, but I believe that only happend in the last 15/ 20 hours based on the increased smoke at startup.
I have no idea what started this, I really don't. I've been a bit remiss with checking the oil - obviously.. :( leasson learned there.
There has alyways been a good deal of fuel knock, since hour new. - I bought it from Wallace and thought it was just the way the daedongs ran..
Possibly it was always a problem, but has gotten bad enough to show on the dipstick?
Are we talking lift or injection? I didn't think I had a lift pump. Just gravity to the injection pump.
I'm happy to replace that seal, when I'm waiting for the injectors to be checked / repaired. It's mowing season soon.. and I would rather only prime this thing once and have it fixed.
Anybody have a part number?
Edit: I guess Kioti calls it a feed pump. Need to go out to the barn and check the manual.
Spot on! thanks - I don't know if I would have thought of that.. Probably would have just pushed them over the counter and asked for them to be checked.
/ ..another DK 35 making oil #9
They all have a lift/feed/fuel pump that takes fuel from the tank and pushes it with only a few pounds of pressure to the injector pump. Here's a link of a DK35 showing part #18 as the pump. Your problem would not be #19. The pump is a diaphram pump and it's this diaphram that can leak the fuel if there was a pinhole in it. Just so you know, this may not be the actual part# because there are listed several engine model numbers. Just check the site for your engine model#. http://www.paigetractorsparts.com/p...4-00385_-_)/01-05|~DK35-M-ENGINE/0105DK350101
They all have a lift/feed/fuel pump that takes fuel from the tank and pushes it with only a few pounds of pressure to the injector pump. Here's a link of a DK35 showing part #18 as the pump. Your problem would not be #19. The pump is a diaphram pump and it's this diaphram that can leak the fuel if there was a pinhole in it. Just so you know, this may not be the actual part# because there are listed several engine model numbers. Just check the site for your engine model#. OEM Parts
10-4. So it's just a simple diaphram pump. I'll probably just order one up, but I assume I can test it for the pinhole with a vaccum pump?
Thanks!
/ ..another DK 35 making oil #11
10-4. I assume I can test it for the pinhole with a vaccum pump? Thanks!
Should work (although it may only leak on compression or at certain positions of the stroke). Be sure to order the gasket too, just in case.
/ ..another DK 35 making oil #12
Thanks! And you're welcome.
As has been suggested you may have a leaky lift/feed pump in addition to some sticky injector(s), sticking injection pump rack, or other things contributing to what was initially an injector knock sound.
What's you fuel supply like- do you have your own tank- local supplier? Sometimes its all about the fuel you are using in your machine, and how clean or dirty it may be.
Did you buy this unit used, and if so how many hours on the clock total?
Marginal parts like malfunctioning injectors, as but one of many examples can do damage over time if not caught, but it sounds like a 'perfect storm' scenario where one thing led to another until fuel diluted your oil. Don't be hard on yourself- at least you caught it before it spun a bearing or worse!
See replies above in your quoted post.
Got an injector place lined up. Going to order the lift pump tomorrow. Should I get new gaskets and heat shields for the injectors? Unit only has ~120 hours.
/ ..another DK 35 making oil #14
With 120 hours, I would think that they would be alright but for $5/injector, I would order them and save if not needed. Whenever I have tried to cut costs, it seems to always bite me in the end. Some of the members have replaced a few injectors with I think more engine hours. Maybe they can give you better advice on the condition of their old parts and if they replaced.
/ ..another DK 35 making oil #15
You may want to see this video:
[ame=http://www.youtube.com/watch?v=qGcEbmGQoBo]Mercedes Diesel Fuel Injector Spray Pattern Test by Kent Bergsma - YouTube[/ame]
These are Mercedes injectors but the principle is the same. You want a highly atomized conical spray with no after drip. Ideally all injectors should "pop" at nearly the same pressure within the spec range.
Thanks for everyone's help.
Ordered up a lift pump & gasket, as well as the injector gaskets & heat shileds.
$75 plus shipping from Michigan Iron.
I will report back with the results of the injector pop tests in about a week or 2.
Fuel usually comes from the offroad pump at the exxon down the road. I live in a fairly rural area, and it gets some decent traffic.. (I've even seen a few dimestore cowboys filling their shiny diesels there). There have been a few times where I've gotten road fuel at different places if I'm on the move.
Dirty fuel could very well be a problem.. and I may look at plumbing a better filter into the system if that turns out to be the root cause.
New used. It is the kubota GST prototype that Wallace had a few years ago.. a brand new 2003 in 2009 serial number is ~000002. I think it had 2 or 3 hours on it when I bought it. but alas no warranty.
/ ..another DK 35 making oil #18
On my CK30hst, the fuel gravity feeds to the lift pump. There is no filter prior to the lift pump and some members have installed one there. If you go to fine a filter, you may not feed the lift pump enough being that it's only gravity to it. If a big enough piece of dirt made it to the lift pump, the diaphram may be damaged but via Michigan Iron, they rarely see that. My actual fuel filter, which probably is the same as yours, should take out anything that would hurt the injectors. I'm careful when changing the fuel filter to not get any dirt in the filter bowl which may go directly to the injector pump and then the injectors. With yours at 120 hours, I can't imagine a problem with the filter. Usually the filters plug and starve the fuel flow instead of dirt just going through. I do use a fuel additive for freezing, cleaning, cetane number change, etc. Members here have various ideas on fuel additive use, so that one is up to you.
Please let us know what you find out. That's how all of us learn.
/ ..another DK 35 making oil #19
Typically, lift pumps fail in one of three ways: an external leak, check valve failure (which can be caused by debris in fuel), and diaphragm failure (which would let fuel leak into the crankcase).
/ ..another DK 35 making oil #20
I'm curious as to what 'fuel knock' is?? Having been around oil burners all my adult life, I've never heard fuel knock.
Please enlighten me??:confused2:
2018 Volvo VNL T/A Sleeper Cab Truck Tractor (A61573)
2018 Volvo VNL T/A...
UNUSED WOLVERINE FORK FRAME (A64281)
UNUSED WOLVERINE...
Caterpillar C18 Industrial Diesel Engine - Serial N8F01121 - Power Unit - Pump Takeout (A63689)
Caterpillar C18...
2016 Dodge Charger Sedan (A61574)
2016 Dodge Charger...
2014 International WorkStar 7300 4x4 Altec A55F 55ft. Material Handling Bucket Truck (A60460)
2014 International...
(4) RUBBER TIRE LOADER TIRES (A62613)
(4) RUBBER TIRE...
