Buying Advice tractor newbie
   / tractor newbie #1
calidude559
Member
merced,ca
none
just moved into a house and it has 10 acres.looking to buy something that can disc the dirt.i was looking at the new holland and brother told me good luck with those.he said everybody is buying kobuta nowadays.i need one that makes the rows for the melons.budget is probably about $15,000.what kind of tractor do u guys think i should look for? uses for the tractor is.
1.planting cherry trees
2.variety of vegables mainly tomatillo,tomatoes,cucumbers
3.watermelons,cantaloupes.
   / tractor newbie #2
Depends on your time but a B-series would get the job done but an L-series would get it done a bit faster but would be over your price limit.
   / tractor newbie #3
Have B2710 and it's a great tractor. have a 48" tiller and a pull behind discer and both work fine.
   / tractor newbie #4
Welcome. How big will the actual garden be?
   / tractor newbie #5
The dealer from whom you purchase the tractor is a primary factor in your selection. They can make a good tractor look bad or bad tractor look good depending on how they serve you. I live where dealers are few and far between. The dealer I work with sells New Holland and Kubota. He treats me like family, and I don't mean the bastard child. He sells a mainly New Holland in the large ag tractors and Kubota in the smaller tractors. He says nothing against the small New Hollands but the Kubota's sell on their own reputation.
   / tractor newbie #6
Check out the Mahindra line--30-40 hp (engine) size would fit in your budget.
Mahindra Tractors - World's #1 Selling Tractor including Compact tractors, Sub-Compact Tractors, Utility Tractors and Farm Tractors with Loaders, Backhoes, Implements, Mowers and more.
   / tractor newbie #7
Nothing wrong with buying used...and $15K can buy a pretty nice used tractor.
My suggestion would be a Deere 4300 or 4310 (1998 to 2004 model years).
Welcome to TBN!!
   / tractor newbie
well i cant really say how many big.but i can tell u that in a few weeks i will be planting maybe 500 of tomatillos,watermelons and cantaloupes.each that is heh:p thanks for the tips guys :D
   / tractor newbie #10
did a quick search and found this!
John Deere 4310 Tractor (2004)
That's a good price...think it will fit your needs?
BTW, I expect that tractor to sell very quickly...if you're interested, I suggest you move fast.
One task you mentioned was planting Cherry trees. If you're planting seedlings or saplings, a PTO driven post hole digger would be a much less expensive option then a backhoe.
2022 RAM 2500 HEAVY DUTY (A55745)
2022 RAM 2500...
More info coming soon! (A55851)
More info coming...
2018 CATERPILLAR 289D SKID STEER (A52709)
2018 CATERPILLAR...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A55852)
2013 Ford F-150...
2024 ArmorLite Aluminum End Dump Trailer (A56435)
2024 ArmorLite...
2016 JOHN DEERE 310SL BACKHOE (A52709)
2016 JOHN DEERE...
