homemade boom for atv sprayer.....ideas?
   / homemade boom for atv sprayer.....ideas?
thanks for the pics.......looks great.....I'll have to see what I can come up with.
   / homemade boom for atv sprayer.....ideas? #23
I have a 15 gal tank with a dang good pump from lowes, it mounts in my riding lawnmowers pull behind cart. It came with a wand, but I quickly realized that it wok ist wasn't going to cut it with my large yard. I went to Tractor Supply and bought two 140 degree boom nozzles, along with the little filters and nozzle housings. Dont forget the metal mounts for the housings as well, i bought ones that slip over pipes with a screw to tighten on one side. The staff there was knowledgable so don't be afraid to ask around. I then bought about 15ft of 1/2 ID tubing from lowes, as well as a couple plastic T splitters to send the tube from my pump out to both of my nozzles. Also, I bought one long piece of PVC pipe, small diameter, not sure of the size, though it's not going to matter as long as you can fit the clamps on. I took this all home, built my sprayer housings, attached them to the PVC pipe with the clamps, about 5 ft apart, then used sheet metal screws to attach it to the lowest point on the rear of my cart. I used this boom to spray my entire yard with weed killer, it is all officially dead. Very proud of my little "invention." give it a try!!! All in all about $50.00.
   / homemade boom for atv sprayer.....ideas? #24
How big is your yard? I just bought one of the TSC pull behinds noted earlier, but plan on mounting on my carry all instead of the wheels it came with. I am doing about 3 acres, was just wondering how many times I would have to refill the 25 gallon tank.
   / homemade boom for atv sprayer.....ideas? #25
I have a 13,000 sq ft front yard, about an acre in the back. I did it all with just one spray nozzle mounted on the center, though for larger I would definitely recommend the whole boom. I can do my front yard on about 1 1/2 tanks with a ten gallon tank. Just make sure it's not windy like here in DE, I basically wasted a tank one day when windy.... Good luck!
2019 MACK GRANITE (A58214)
2019 MACK GRANITE...
John Deere 1025R (A53317)
John Deere 1025R...
2014 FREIGHTLINER CASCADIA (A58214)
2014 FREIGHTLINER...
2012 LEDWELL 48FT DOVETAIL TRAILER (A58214)
2012 LEDWELL 48FT...
2020 VOLVO 760 TANDEM AXLE SLEEPER (A57880)
2020 VOLVO 760...
S/N: 1240824 (A55853)
