Price Check Used implements
/ Used implements #1
CORamos
Douglas, MA
Kubota BX25
Someone is selling a used 60" hydraulic snow blade (BX2763A), sweeper (BX2537A), and snow blower (BX2750C), and quick-hitch. It's a package deal. What's a good price for everything?
I'm really only interested in the snowblower, since I have the blade, and don't really need the sweeper. Is there a big market for the sweeper and blade? I'm thinking I could sell the items I don't need (extra blade and sweeper), and maybe end up with a snowblower at a really good price.
Your thoughts?
/ Used implements #2
Buying and selling used implements is a bit of a risk...depends on how good a dickerer you are.
If you can get all three implements for a reduced price and don't mind setting on them for a bit, you might make a few bucks on the sweeper and blade.
You'll see a number of blades on Craigslist. Brooms aren't too common.
/ Used implements #3
Not sire, but i know sweepers are relatively expensive. Are the sweeper and blower 3 pt or fel mounted?
/ Used implements
They fit the Kubota BX series (and perhaps B series also), and use the quick-hitch subframe to connect to the front of the tractor.
/ Used implements #5
Not sure what used would be, but I looked at a snow blower and sweeper for my B series. Prices seemed to be in the vicinity of 3 - 5k for each one depending on the exact brand and size, so I'd expect ones sized for the bx to be lower. I know that the front mounted implements tend to hold less value than a 3pt because they are relatively tractor specific. Depending on age and condition I'd guess that you might be looking at 1 - 2k per item plus the plow. I would check tractorhouse, craigslist to see what similar things go for used and look at some of the attachments websites to get a feel for new prices. If you do pick it up I'd be interested to hear what you sell the sweeper for as I've been thinking of getting one of those, but only have limited use for it (clearing sand & leaves off a private road a few times per year) so can't justify a new one.
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2020 CHEVROLET...
2007 DRAGON 130BBL VAC TRAILER (A60736)
2007 DRAGON 130BBL...
2008 UNKONW  SPOOL TRAILER (A63569)
2008 UNKONW SPOOL...
2014 CM TRAILERS ENCOLSED CARGO TRAILER (A63569)
2014 CM TRAILERS...
SHOP MADE 36' T/A GOOSENECK SHOWER/EYE WASHTRAILER (A63569)
SHOP MADE 36' T/A...
2023 Kubota Z412KW Zero-Turn Mower with 3-Bag Bagger System (A63118)
2023 Kubota Z412KW...
