B3300SU Transmission Surge
/ B3300SU Transmission Surge #1
Ralph B
Kubota L3130D
When I start to move the tractor begins to go then it surges as though the transmission just got a delayed flow of fluid? Especially noticeable when in third (high) range. Fluid levels are fine, and pedals seem to be properly adjusted. Anybody know what's causing this?
/ B3300SU Transmission Surge #2
HST or geared? The HST has sensors or something that helps the driver by trying to match the demands on the tractor to the input of power on the HST models. Don't know that much about the geared since I only have one of them and don't use it much. I think the surge is common on the HST. Get on a flat paved road, no dips or hills, and set it at a constant speed with no change in throttle pressure and see if it does it. The slightest change in demand, hill up or down, will change it by increasing or like downshifted.
/ B3300SU Transmission Surge #3
The B3300su is HST, and has no sensors on the transmission.
The surge is normal and shouldn't be worried about it. It is just the change in pressure in the pumps that is causing it. A little bit unrefined, but not a problem by any means.
/ B3300SU Transmission Surge #4
Common in the B's. Normal....unfortunately.:(
/ B3300SU Transmission Surge #5
My B3200 is the same, I don't worry about it. I have had it for 2.5 years and it actually has decreased a noticeable amount but is still present.
Thanks for the responses! I've owned L series tractors in the past and never had this experience so thought I should look into it. You've put my mind at ease - and yes it is a bit unrefined, isn't it?!
/ B3300SU Transmission Surge #7
My former tractor (B7510) and my current B7800 both do the same, especially when used cold. When the fluid warms up it is not bad. If fine movement is required just use Lo range.
/ B3300SU Transmission Surge #9
just wondering, what type of terrein (hill/flat) you are on and what rpms are you using when this happens to you?
i have a b7800 (very simular to b3300su) and this has not been a problem for me for the 850+ hours i have used it. the only time it will do this for me is if it is cold and oil not fully warmed up, or in too high a gear for use, or to low rpms. i run my rpms at least 2300 almost all the time. maybe i just got lucky with my tractor too since a lot of others mentioned this in this thread. anyway just some info for thought.
/ B3300SU Transmission Surge #10
You got lucky, my 2620 I had was smooth as silk yet my 3200 is jerky no matter what rpm it is at.
/ B3300SU Transmission Surge #11
you running the super udt fluid in the hyd. trans. with kubota filters? just wondering for my info.
/ B3300SU Transmission Surge #12
I changed the fluid at 50 hrs and went with CaseIH Hy-tran fluid but I did not notice any difference. As for filters I stick with Kubota filters. Expensive yes but I consider them excellent quality.:thumbsup:
/ B3300SU Transmission Surge #13
I use Super-UDT and Kubota filters and always have. The transmission lurch only happens when the Hydraulic fluid is not up to operating temperature. Then it's pretty much gone. I use Lo 60% Med 39% and Hi about 1% of the time. So. It's a none issue for me anyway.
/ B3300SU Transmission Surge #14
same with me. in fact i only notice the problem with my b7800 when i am pulling out of my shed first thing=usually not fully warmed up and/or i have it at low rpms just pulling out. it will do it once with in the first 5 feet i move it then that is it. anyother time it has happened to me is if i was transporting it in high range and i get lazy and try to take it up a hill i should have shifted to medium on. other then that i never have this surge problem. i run my rpms atleast 2300. gears= low=50% med=49% high=1%.
not sure, but does it have a two stage pump and it might be kicking between stages causing this surge or lurch forward?
/ B3300SU Transmission Surge #15
i actually just priced kubota filters against wix (napa) and to my surporise, the kubota filters were not any more expensive. some of napa's filters were a little more (not much), some of kubota's filters were more (not much). i priced all the filters, air, oil, hyd/trans, fuel. i am in the north east. maybe prices with competitors vary elsewhere??? i too will stick with the kubota filters.:thumbsup:
