7520 suction strainer
/ 7520 suction strainer #1
jrchafin
Mahinda 7520
If I take apart this suction strainer won't all the trans fluid dump out? How can it be cleaned without draining first?
Shameless bump.
/ 7520 suction strainer #3
I believe you are correct sir. I will clean mine when I change fluid next month.
/ 7520 suction strainer #4
You will lose a lot. You could limit this greatly if you could get the tractor in a steep forward downhill orientation. If youre loader equipped you could accomplish this on mild incline or even flat, by backing the rears up on stable, levelled blocks, then lifting the front with loader and removing front wheels and letting the front down on the ground.
larry
I'm just going to wait until the first trans oil change. I have 500 hours and haven't cleaned this strainer yet. All my hydraulics work fine. I've done the filters on schedule. Is there any reason that it must be cleaned now?
/ 7520 suction strainer #6
No, unless it has significant debris ... which you cant know til you look. The strainercatches all the bigger debris that may be in the trans when its put together. After that its kinda useless and presents an added suction restriction. I removed mine at 1st oil change.
larry
UNUSED WOLVERINE QC1-26-20G UNIVERSAL HITCH (A62131)
UNUSED WOLVERINE...
New/Unused 7ft Fork Extension (A61166)
New/Unused 7ft...
UNUSED RAYTREE RMBD50-50" HYD DRUM MULCHER (A62131)
UNUSED RAYTREE...
LOT OF MISC SAWS (A62131)
LOT OF MISC SAWS...
UNUSED IRANCH MINI HYD THUMB (A62131)
UNUSED IRANCH MINI...
UNUSED WOLVERINE DB-15-84W 84" HYD PUSHER BLADE (A62131)
UNUSED WOLVERINE...
