Dirt Moving Cheap Cable Trencher?
   / Cheap Cable Trencher? #1
WeldGuy
Kubota BX2200
Has anyone made a cheap cable trencher attachment for installing wire about six inches down? We'll be installing some invisible fencing for the pup.
   / Cheap Cable Trencher? #2
Yes I did... Buried coax with it. Worked very good.
basically I took two 8" x 6" plates of steel (1/4 plate), welded the 8" edges together to form a V with the wide end of the V about 4" apart, then welded bracing in to the open end of the V.
Then on what would be the top of the V closer to the point I welded two 3/4" nuts per side. (I did this with them on 3/4" all thread so the threads would line up).
I then took a piece of scrap 3" x 3" 1/4" angle and drilled two holes in it.
To use it you basically slide it over a tooth on the back hoe and tighten the nuts clamping the V under the bucket and the angle in the bucket.
I straddled the wire with the tractor and dragged a ditch about 100', while the wife simply put the wire in the ditch (which ended up about 5 or 6" deep) and pushed the dirt back covering it.
   / Cheap Cable Trencher? #4
Are you driving the tractor forward and dragging the backhoe? Or are you pulling forward and manipulating the backhoe every 3-4 feet? Yeah, a picture would be great.
Deano
   / Cheap Cable Trencher? #5
I used a subsoiler to bury some thin walled PVC hose - don't see that it would be functionally different from doing the same with cable. Warning - the following picture includes duct tape:
   / Cheap Cable Trencher? #6
I have a single bottom plow and removed the wheel which is to set the depth. I dropped it and drove forward and it cut the most perfect 6"x6" trench I've about every seen with the removed dirt piled on one side. I did it for drainage and it did it so clean and easy that I did about 5 times as much as I needed. So, if you have a single bottom plow or can borrow one, it's something to consider. Just have to come back along and cover your ditch with the dirt piled on the one side.
   / Cheap Cable Trencher? #7
I am in NH wedge is in CT I will have wife take a picture and send it. I will post it later.
I used the backhoe (I had a case 680 at the time) to pull about 12 feet at a time. I didn't have to use the stabilizers the park brake was enough to hold the tractor.
By using the boom, dipper and bucket I could stretch way out and pull the dipper towards me while lifting the boom and rolling the bucket.
It did a really good job. the grass was back to normal within a couple weeks.
   / Cheap Cable Trencher? #9
For a dog fence wire we just use a edger if you don't have one a local rental store should be $50 or less for the day. Hard to build something for less.
   / Cheap Cable Trencher? #10
Mine looks ugly compared to the above or the ones in the link
CATTLE CATCH SHOOT (A52708)
CATTLE CATCH SHOOT...
Rears MTG Co 105G Stainless Steel Pak-Tank (A59225)
Rears MTG Co 105G...
2015 Ford Taurus Sedan (A56859)
2015 Ford Taurus...
2004 MACK CH613 WATER TRUCK (INOPERABLE) (A58214)
2004 MACK CH613...
SOFTSTART W/ ACROSS LINE BY-PASS STARTER (A58374)
SOFTSTART W/...
pressure washer, and trailer (A56859)
pressure washer...
