Bad Battery on BX22TLB
/ Bad Battery on BX22TLB #1
nnicklas
Glen Burnie MD
My soon to be 10 year old BX22TLB won't start. Seems to be a dead battery, I did a charge and the alternator and oil lights come on for the first key click and on the second the glow plug indicator barely lights figure the battery is finally giving up the ghost. The manual talks about replacing it with a 526RA 80 min reserve and 535 CCA. Any suggestions on a replacement battery? The OEM battery is a deka but when I looked on line I found one close but the terminals where square posts similar to a small mower battery rathern than round posts. Any recommendations would be appreciated.
/ Bad Battery on BX22TLB #2
I would go to the nearest Kubota dealer for a battery.That way you know you are getting the proper battery,both for fit and performance.
/ Bad Battery on BX22TLB #3
Sounds like a pretty good run, I would try to get the same battery if it lasted 10 years for sure.
/ Bad Battery on BX22TLB #4
I had the Kubota dealer change mine after 10 years this past winter and he used an Interstate I-26R battery was $64.09.
Interstate Batteries
2025 Auger Drill Bit Mini Skid Steer Attachment (A61572)
2025 Auger Drill...
2014 Nissan Altima Sedan (A61574)
2014 Nissan Altima...
2015 FORD F-350 SUPER DUTY (A63569)
2015 FORD F-350...
2018 Ram 1500 Reefer Meal Delivery Truck (A61573)
2018 Ram 1500...
Location Tampa, FL (A61567)
Location Tampa, FL...
(2) BUCKETS OF GALVANIZED BOLTS (A64281)
(2) BUCKETS OF...
