Clutch rod heating
/ Clutch rod heating #1
irquomai
Sneads, Fl.
ym2000
I have ym2000 that leaks fluid where the rod attached to the clutch pedal enters the bellhousing. How can I replace that bearing?
/ Clutch rod heating #2
If it is where I'm thinking, I don't think there is supposed to be any fluid. Can you post a picture?
/ Clutch rod heating #3
Yes its supposed to be dry in the bellhousing. You have either a rear main engine oil seal leaking or the front transmission seals leaking. I personally wouldnt worry about it until it starts causing problems such as clutch slippage or excessive oil consumption.
/ Clutch rod heating #4
Yet your correct there should be nothing in there. These tractors were designed to run in deep water and thus have a drain plug in the bottom of the bell housing. Its a square headed plug about 1/4 inch. I would just pull it out right now so that the fluid does not get on your clutch. Its either hydro fluid or engine oil like stated previously.
/ Clutch rod heating #5
Might be something as simple as a leaking drain plug.
/ Clutch rod heating #6
There is not a drian plug into the bell housing. The drian plug i refer to is in the bell. Its used to drain any water fluid that makes its way into there that should NOT be there
20' One-Trip Shipping Container (A66285)
20' One-Trip...
New/Unused 20ft X 20ft Steel Carport (A65583)
New/Unused 20ft X...
1997 International 3800 School Bus (A64194)
1997 International...
Metaltech climb and go (A64553)
Metaltech climb...
(2) 15.0/55-17 TIRES W/ 6 LUG RIMS (A64280)
(2) 15.0/55-17...
New/Unused AGROTK 72in Quick Attach Brush Cutter (A65583)
New/Unused AGROTK...
