Excess Grease
   / Excess Grease #11
What kind of grease do you use? At work we started using black moly. I have noticed that it does not seem to run nearly as much as regular grease. It was recommended by CAT. It is more expensive and I have started using it on my tractor and I don't think it makes as big of a mess.
   / Excess Grease #12
Many aircraft manufacturers recommend black moly grease for the landing gear areas. Struts and associated parts. Usually the base grease has about 5% moly added.
   / Excess Grease #13
While we are on the topic of grease, I have tried 3 different grease gun tips and they all lock onto my zerks like there is no tomorrow. I can't get them off without unscrewing the 2 sections. I have all kinds of equipment with zerks and never had this problem before. The recessed fittings on the loader are the worse but all are terrible. Any tips would be greatly appreciated.
   / Excess Grease #14
I agree Chris. I have tried all the barrel type couplers and they all can stick on the zerk. MY SOLUTION;I quit using them and went to a needle point. You get a needle point sitting on the end of a good lincoln pistol grip grease gun and you will cut your time in half that you used to take to lube your tractor. Don't get just any needle point replacement grease tip either. I just got a good quality lincoln needle tip with a 2 or 3" needle tip that you line up with the center spring pin in the center of the grease zerk an push in. With the pistol grip gun you can control the pressure on the grease gun tip with one hand while squeezing the pump handle with the other, It also helps to replace the steel tube on the tip of the gun with a 6-10" length of rubber hose extender.
rimshot
   / Excess Grease #15
I think they are alway hard to get off when they are new. I just jerk them hard and they usually come off. But I wonder if you could use a little drimmel tool and grind the inside just a little. Just a though. I think a little chain saw grinder would fit right in the middle.
   / Excess Grease #16
The grease gun connector can be adjusted by rotating the tip. There is a thread addressing that. Be careful with the WD-40, it is a solvent (not a lube) and if you spray where you grease you can defeat the purpose of greasing.
   / Excess Grease #17
They lock on so good if you yank you break the fitting. Don't ask me how I know that. :)
I've seen needle tips. Never knew what they were for. So you just press the point into the ball of the fitting?
   / Excess Grease #18
I also know about that too. having to then get the threaded part out slows down the grease job and then you have to find the correct fitting.
Needle point tips are designed for use with the flush push in fittings. Used where you could get lines, cables etc. caught on them or just because the engineer decided it was a good idea. But, using it on a regular Zerk has become popular.
I adjust the regular fitting to have the hold I want and pull off I want.
   / Excess Grease #19
Chris I usually loosen the tip, push it on, and then tighten it a bit, pump in grease, then loosen it a little to get if off easily.. takes just a few seconds to do and ends all of the struggling. here is a link:
http://www.tractorbynet.com/forums/oil-fuel-lubricants/222738-grease-guns-5.html
The fun begins on post 49
Or this one:
http://www.tractorbynet.com/forums/owning-operating/203295-grease-gun-screwdriver.html
good luck..
James K0UA
   / Excess Grease #20
I bought a second gun recently so that I could keep two types of grease on hand -- its a JD pistol grip gun (the green one). The tip is a real bugger to get off, even when the adjustment threads are loosened all the way. I did find that I can pop the tip off the fitting much easier if I pivot the tip at an angle before pulling, but there are a couple fittings on my FEL where there's not enough space to do that. So I end up having to unscrew the tip all the way off.
Next time I have to grease, I plan to take the tip apart first and see why it's so darn stubborn. I may just buy another tip. My old grease gun was never this fussy -- in fact, I never had to fiddle with the tip threads at all on that one. It holds tight and lets go when you want it to.
2013 PETERBILT 389 (INOPERABLE) (A55745)
2013 PETERBILT 389...
2021 Kubota RTV X900 4x4 Utility Cart (A55787)
2021 Kubota RTV...
Hilti TE 2000-AVR Electric Jack Hammer (A55973)
Hilti TE 2000-AVR...
SCAN TO RECEIVE TEXT UPDATES (A52708)
SCAN TO RECEIVE...
2014 Ford F-150 Pickup Truck (A55973)
2014 Ford F-150...
20 X 20 CAR PORT (A58214)
20 X 20 CAR PORT...
