Hdyraulic Lift Return
/ Hdyraulic Lift Return #1
Galena
Zebulon, NC
L3130
Within the last year my 3-point hitch lift on my L3130 will not go down in a timely manner. Last year it started getting slower and would take about 30 seconds, but today it took about 5 minutes as I was installing the belly mower. It raised fine, any idea about the potential problem?
/ Hdyraulic Lift Return #2
Do you have a 3 point regulating speed valve on your tractor? Mine is installed between the heels of my boots. It can actually close the system. Philip.
/ Hdyraulic Lift Return #3
Mine as well, freaked me out till I played with it;)
Not sure if I have, but exactly where is it located, under the seat or floorboard and what does it look like?
Thanks
That was the problem! For all the hours I have spent on the tractor I have paid attention to that control, works correct now!
Thanks for the input.
/ Hdyraulic Lift Return #6
Read your manual!!!!!!!
PHILIP8N, so glad to see you have mastered the use of your "!" key on your keyboard maybe you can now move to other keys
/ Hdyraulic Lift Return #8
I am glad I could help you with the question in your origial post. There are many more things you could learn about your tractor in addition to the 3 point flow control valve with just a hour or two of reading. Not only do I know my keys, but I know my tractors. Maybe you should move on and learn more about your tractor and worry less about my keys?????? Oh, your welcome. Philip.
/ Hdyraulic Lift Return #9
Pricklely I always though of a spikey bush but now looking at the root of the word maybe that is a little harsh, perhaps the flies are out;) Lets all get along now, lol.
/ Hdyraulic Lift Return #10
I won't use the ! key, but highly recommend reading/re-reading a manual. Even though I have run our tractors for a minimum of two years, occasionally I get a manual out and go through it again.
Thanks everyone, I appreciate the information/help
/ Hdyraulic Lift Return #12
Appologies if I came across a little coarse. I will keep my 'keys' in my pocket.:)
/ Hdyraulic Lift Return #13
Ya it is surprising what a little experience does to the reread, lol.
/ Hdyraulic Lift Return #14
It's also surprising, sadly, what a reread does to one's opinion of their own memory, sometimes. Other times, it's very rewarding--especially when you read it before operating, as my grandfather would always insist that I do. Bless his soul.
My Hoe
2010 Ari Hetra HDML-8 15,000lb. Heavy Duty Mobile Column Lifts (A61572)
2010 Ari Hetra...
UNUSED WOLVERINE 44" HYD MINI STUMP GRAPPLE (A64281)
UNUSED WOLVERINE...
KBH 25 TON TENDER (A61307)
KBH 25 TON TENDER...
Caterpillar D7G Tractor Service and Parts Manuals (A63117)
Caterpillar D7G...
2012 Infiniti QX56 (A61574)
2012 Infiniti QX56...
2013 Komatsu WA320 Wheel Loader (A60352)
2013 Komatsu WA320...
