Adding stiffener to FEL
/ Adding stiffener to FEL #21
I did find missing pins - on both sides (see pics). Does this mean the bucket torqued off at the bottom at some point on the side that broke?
Any recommendations for keeping the pins on? I can certainly check every once in a while, but it seems like better attachment would be best.
/ Adding stiffener to FEL #22
I haven't lost a lynch pin yet on the pivot pins. I noticed you have yours going through from the lower side of the pin holes. I drop mine in from the top so if the keeper ring gets caught on something, they have a lesser chance of falling out. Hopefully that helps them little from falling out. I suppose you could always use bolts with self locking nuts like those used on my Kioti bh bucket pins. I've never had a bolt loosen.
/ Adding stiffener to FEL #23
I have never lost a lynch pin there either, but it certainly could happen.
Your point about the pin orientation is a good one.
My hoe also uses bolts and nuts, but I rarely take those pins out. I have
lost a few nuts and bent the bolts, however. On my FEL, I change from
forks to 4-in-1 bkt 2x per year, so bolts are out for me. (Maybe I change
my tune if I do lose a pin!)
I just made some replacement pins for a Bobcat 4-in-1 bkt and I like how
the pins are retained: a small pin, which goes thru the pivot pin, is bolted
to the side of the clevis. Nice setup.
/ Adding stiffener to FEL #24
I have the same loader. What missing pin are we talking about so I can make sure to check mine. Thanks.
/ Adding stiffener to FEL #25
I have a Kubota L3240 with an LA724 loader. I have broken the same links (both sides) over the past year. The problem was that the pins "were" secured with a metric bolt and locknut. The bolt was too long, and when curling and dumping the bolt would get bent. Eventually it fell out and the bracket swung loose. Since only one side of the connection came loose, I didn't notice anything wrong with the bucket. My "fix" was to replace the brackets with new kubota links (about $25 each) and replaced the bolts with 1/4" cotter pins. Now nothing can get bent and it has held fine.
I also replaced all of the metric pin bolts and locknuts with grade 5 hardware and locknuts on all other connections. I removed all of the pins when I did that and found that two of the lower link pins on the QA bucket were actually broken. MORE stuff to fix, and a GOOD reason to do routine lube and inspection. I found the broken pins BEFORE they "found me." No complaints here, I use the heck out of my loader. "Fair-Wear-and-Tear" has a new meaning when dealing with loaders.... Heck, IF you are not "overloading it," how can you justify even having one.....
/ Adding stiffener to FEL #26
They're talking about losing the lynch pins. These are the pins with the wire ring attached to them. The same kind that are used on the 3pt attachments where they go through the 3pt arms. These lynch pins may fall out and then the one inch diameter pins, that are the pivots for the QA adapter or a pin on bucket to the fels arms, start to move out of position.
/ Adding stiffener to FEL #27
Thanks victor. I understand new. They look like there is no way they could fall out but who knows?
/ Adding stiffener to FEL #28
If the pin loops snag on brush they can easily be pulled out. I've never had that problem with mine on the loader (not honestly sure I've ever seen them on the front) but I have had this happen with the 3PT attachments. In fact I think it has happened at least twice maybe three times. Some of these pins should just be replaced with locknuts and bolts. Who ever needs to remove the 3PT arms or the QA receiver anyways?
/ Adding stiffener to FEL #29
I take my 3 pt arms off every time I put the backhoe on Island. Otherwise the darn things can get in the way of the backhoe sub frame.
rim
/ Adding stiffener to FEL #30
rim
Now that you mention it, I do too on my DK. However, I don't use the flip over loop pins but rather the pins with a hole in the end to insert a ring. I used lock nuts and bolts on my CK20 after the original pins fell out during use. Has only happened once on the DK 3PT and I still use the pins with capture holes.
/ Adding stiffener to FEL #31
rim
I have to correct what I said last week. I don't take my 3PT arms off. I just take off the adjustable spring loaded linkage thingie at the end of the 3PT arms. That gives enough clearance so there is no interference with my BH mount. It has been about five months since I dismounted the BH and I forgot about how I do it until I saw an old photo. Removing the sliding linkage thingies only takes a few minutes and they are easily removed just standing in back of the tractor rather than needing to crawl around near the axle.
/ Adding stiffener to FEL #32
IT, If the second pic shown here is of the rear of your DK-40 I suggest you look at Murphy's (recent) DK-40 backhoe mount thread pics to see the one which shows the updated routing of the hydraulic line to the red vent tube on the right side of your rig which then gets replaced with the newer design QD fitting. The vent then attaches to the left side of the upper housing, using a smaller black tube in the shape of a shepard's crook, on a smaller brass colored tube). This supposedly gives better flow to the hoe and therefore more usable power to the hydraulics with no other effects to the system's overall design. I can't testify to this beyond the fact that it was installed by my dealer no charge on both my DK-35 and my DK-40. I have not used a DK with the original setup- like you have currently, to compare output(s), but I can say, why would the kit have been made available if it didn't offer improvements.
PM me or Murph if you have specific questions- (though he may not know it was an upgrade to his system), it probably just came with it from the dealer.
24" Mini Excavator Bucket (A66285)
24" Mini Excavator...
2004 AGCO Gleaner 3000 Corn Header (A61307)
2004 AGCO Gleaner...
John Deere 6105D (A64126)
John Deere 6105D...
Landhonor 3Pt Potato Harvester (A66285)
Landhonor 3Pt...
2023 BOBCAT T770 SKID STEER (A62129)
2023 BOBCAT T770...
2020 INTERNATIONAL LT625 48" SLEEPER (A62613)
2020 INTERNATIONAL...
