Deere 317 will not start
/ Deere 317 will not start #1
Johndeere3720
Padawan Tractor Learner, Advertiser
NW Oregon
Bobcat T650, MT55, E42R, E10, John Deere 4410, 4200, x500
Well, I should have known it was coming, the battery finally gave way on my 317 last night. It took a while to figure out how it comes out and I am in a pickle, the boom must be raised to remove the battery. :confused2: How am I supposed to raise the boom if I cant even start it? I have no other machine around capable of lifting the boom either. I tried jumping it with both the battery on the pickup and a booster and when you turn the key you get nothing. First time i went to start it i got a long beep when i tried to start it and now nothing. The gauges do turn over now when you're in the seat however the head lights will not come on. So what do I do now? I know i need a new battery, i had one that I though might work but it is too small so that's out of the question. How do I remove the old battery? The only way I could see it coming out is tipping it on its side which would get battery acid all over so I would prefer not to go that route. I believe I have an error code off of it, F9D5 which I browsed through the manual and found nothing. Any ideas guys? :confused:
/ Deere 317 will not start #2
Maybe flip the machine on its side and cut a inspection hole with a sawsall.
/ Deere 317 will not start #3
Have you actually tested the battery? It should start if you are boosting it, so I would think that you probably have a bad connection (dirty connections) and that is stopping it from turning over.
I will have to check again, the connections appeared clean but I will take a wire brush to them to make sure. I will also wire brush the ground cable. :)
You can see by the pictures what kinda space i have to work with, the battery will not come out with the boom down. :confused2: Poor design if you ask me. :ashamed:
/ Deere 317 will not start #6
Man, That is tight. I can't believe JD did not see that coming. How many machines blow a battery with the boom up? Very bad design.:thumbdown:
Okay guys, last night I went out and cleaned the battery cables, terminals, and the ground with a wire brush. Hooked the battery back up along with the booster and got in the cab, still no response from the switch. By now I was stumped, so i put everything away for the night. I kept thinking about where else i hadn't looked and then I realized why didn't I look in the fuse box? When i turned the key it usually made at least a click which was the solenoid engaging. However it wasn't doing that plus the lights would not come on. Of course it was already dark out when I thought about it so this morning I went out and took off the fuse box cover to see what the fuses looked like.
Continued in next post....
I pulled out the first fuse which goes to the ignition switch. Once I saw it i had to pull out the second one to compare. :laughing: As you can see, this is why my ignition switch was doing nothing. So I knew I had some extra fuses, I went in the garage and found out i had atleast 5 brand new fuses. So I grabbed one of the new fuses, stuck it in, and put the key in the ignition. Without the booster, she fired right up. :D:cool: So i pulled it out of the barn, took the bucket off, and parked it out of the way with the boom up so I could pull out the battery. I keep having to jump it so I am still getting a new battery but i am so glad I got everything figured out. :D:thumbsup:
/ Deere 317 will not start #9
Good Job!!!!
Just got back from town with a new battery. I called Deere before we left and they wanted $186 for a battery. Went to Les Schwab and they wanted $116. So I got the Les Schwab battery which even has better cold cranking AMPS than the Deere plus a handle so it is easier to put in.:thumbsup: But I still went down to Deere and got some parts for my L118 and a new headlight for the 317 as a spare since a tree limb destroyed one a couple weeks ago but i luckily had an extra to swap it with so I dont have and ugly skid steer. :laughing::thumbsup: I also grabbed an SMV bracket so I can mount my SMV sign to the back of the 317 for when I am operating on the neighborhood roads. :thumbsup: I still have to install the new battery along with a hydraulic line i got a while ago after I found that one had been crushed.
Battery is installed, hydraulic line is changed, the 317 is ready to go. The new battery is a little taller though so i need to make a new bracket to hold it down but no big deal. :thumbsup:
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
2016 Peterbilt 579 Automatic High Top Sleeper (69") (A62613)
2016 Peterbilt 579...
HARGEE 18' BOGGIE AXLE METAL TRAILER (A63291)
HARGEE 18' BOGGIE...
2012 International WorkStar 7300 AWD Altec DC47TR Insulated Digger Derrick Truck (A60460)
2012 International...
UNUSED INDUSTRIAS AMERICA C10 10' FEEDER TROUGH (A60430)
UNUSED INDUSTRIAS...
JOHN DEERE 5075E TRACTOR (A63291)
JOHN DEERE 5075E...
