50 hour service questions
   / 50 hour service questions #31
given your location, think you made good choices on hydro & engine oil types. did you go with 80/90 GL5 in ft axle/hub. probably okay on that, i went with it too.
lots of discussions on break in before synthetic, etc, but i wouldn't worry unless there's noteworthy engine oil consumption (rings not fully seated, etc) then go back to rotella dyno 15/40 for a few changes.
i also agree with the 100 hr/ or annual change. and filter every time. u done good
   / 50 hour service questions #32
With the high compression of a diesel, I would say the rings are definitely seated at 50 hrs.
   / 50 hour service questions #33
On big diesel engines such as 600 HP C-15 CATs using synthetic oil, I have seen final break-in occur in the 15k to 30K mile range or roughly 300 to 500 hours
   / 50 hour service questions #34
Is this from oil consumption data or ?
Towable Dewatering Pump (A59228)
Towable Dewatering...
ST225/75R15 Trailer Tires (A55788)
ST225/75R15...
2006 Trail King RGN 45ft. Heavy Haul Lowboy Equipment Trailer (A60460)
2006 Trail King...
2021 MacDon FD135 Flex Draper - 35' (A59814)
2021 MacDon FD135...
2017 CATERPILLAR 305E2 CR EXCAVATOR (A60429)
2017 CATERPILLAR...
2015 Ford F-350 4x4 Service Truck (A59230)
2015 Ford F-350...
