John Deere 2210 Electircal Problems..Any Ideas???
/ John Deere 2210 Electircal Problems..Any Ideas??? #1
pjputney
Traverse City, Michigan
John Deere 2210
My John Deere 2210 just died yesterday ...its never had a problem... but it died and refused to start a couple of times when it was in gear, but started up ok in neutral...then it just died completely and I can get nothing from it. No fuses blown, battery terminals are clean and everything looks right but no electrical to starter when you hit switch. I know there's a couple of safetly switches on it.....does anyone know where they are and how to jump them? Where can I get a service manual for this tractor? Any ideas?? thanks Phil
/ John Deere 2210 Electircal Problems..Any Ideas??? #2
i have a L130 and knocked the wire off the electric clutch,and did the same thing.i would check that out.it has happened a few times since,bad design.
/ John Deere 2210 Electircal Problems..Any Ideas??? #3
:welcome:
The tech/service manuals are available through Deere, or oft times on eBay.
They are priceless IMO.
/ John Deere 2210 Electircal Problems..Any Ideas??? #4
PJPutny,
You can find the operators manual easily by going to JD's web site and look there.
Link to online operators
OMLVU14461_G3
I found this section in the operation part of the manual regarding these safety hat.
Testing the Neutral Start Switch
1. Sit on operator's seat.
2. Disengage PTO.
3. Move the transmission range shift lever to the H (high) or L (low) position.
4. Completely depress the forward or reverse hydrostatic drive pedal.
5. Turn key switch to START position.
Result: Engine must not crank.
Testing the Power-Take-Off (PTO) Switch
2. Move the transmission range shift lever to the N (neutral) position.
3. Engage PTO.
4. Turn key to the START position.
Testing the Seat Switch
2. Return hydrostatic travel pedals to neutral position.
3. Lock park brake.
4. Start engine.
5. Move the transmission range shift lever to the H (high) or L (low) position.
6. Raise up slightly from operator's seat. Do not dismount machine.
Result: Engine shut-off solenoid must de-energize in 1/2 second, causing the engine to stop.
Thanks for the link, but I have the operator's manual and its not helping. I need a service manual.. any ideas where I can get on of those without paying $150??? thanks
/ John Deere 2210 Electircal Problems..Any Ideas??? #6
You can buy an electronic copy from Deere for typically half the cost. That is where I got mine.
/ John Deere 2210 Electircal Problems..Any Ideas??? #7
Do a search on my user name for 2305 won't start or something close to that wording and there is a test page ....maybe a diode below dash..
/ John Deere 2210 Electircal Problems..Any Ideas??? #8
Put some jumper cables on it from your truck. If it starts, buy a battery. Do you still have the original battery in it? If so, your luck just ran out. 3 to 4 years is about the average life for them.
/ John Deere 2210 Electircal Problems..Any Ideas??? #9
Hi, this happened on a 6420 I was driving, The radio cut out and then about 20 minutes later when I tried to move it would beep at me. Shut the thing off and it wouldn't start even with a new battery.
Found out the alternator went bad. :confused2:
/ John Deere 2210 Electircal Problems..Any Ideas??? #10
you can get a service manual at selectmanuals.com downloads up to 5 times for 30 bucks
2006 INTERNATIONAL DURASTAR 4300 (A67714)
2006 INTERNATIONAL...
2009 CATERPILLAR CP44 PADFOOT ROLLER (A65056)
2009 CATERPILLAR...
2014 MAC FLAMELESS HEATER  (INOPERABLE) (A68842)
2014 MAC FLAMELESS...
2021 BOBCAT T76 R-SERIES SKID STEER (A65056)
2021 BOBCAT T76...
Unused 2022 Hustler Lift Max LE110 SS Bale Forks and Frame Tractor Loader Attachment (A66734)
Unused 2022...
3147 (A63117)
3147 (A63117)
