Mx5100 let me down!
/ Mx5100 let me down! #61
I have methenol and water in my rear tires. I wanted Rim guard but it's a little harder to find in NC. The only time I felt a rear tire come off the ground is when I left my box blade back at the house and I was picking up some #1 rock (about football size). More rock was to one side of the bucket. As I lifted it up the tractor teetered a bit. It just let me know to respect it. I kept the load low to transport. I now keep the box blade on the back doing loader work. I haven't had any problems with my MX5100 in this configuration.
HP
/ Mx5100 let me down! #62
Over the weekend I took the loader off the mx5100 and all the sudden it hit me I had my 8ft blade still on and I was surprised it didn't feel light. But I also didn't go do any work, I was more just playing around and took the loader of for the first time and it went back on.
/ Mx5100 let me down! #63
No horse in this race yet (not trying to start any brand wars here), but this thread reminded me of this [ame="http://www.youtube.com/watch?v=Hz9bGdaRbnk&feature=player_embedded"]video[/ame].
/ Mx5100 let me down! #64
that mahindra did do it but at the end you can see the wheels slipping and lifting a little
/ Mx5100 let me down! #65
The Mahindra did do it, and I do think a couple (Deere specifically, and my bias aside) could have done it if the operator had rolled the weight back first like on the Mahindra instead of lifting it, Mahindra was also closer to the ground. Without ballast, though, the MX5100 would not be able to handle it. As stated in the video, the Mahindra has 40% more built in weight. All the brands would be able to handle the load, if they were to ballast properly. And who's to say some of the tires (Mahindra) are ballasted? Not to be the suspicious type, but we can't go off of what we see alone.
/ Mx5100 let me down! #66
:laughing::laughing::laughing:
"built in weight"
ALL of those tractors would have needed ballast to properly and SAFELY move that load.:thumbsup:
/ Mx5100 let me down! #67
You will notice also he has it in 4 wd. A slight cheat.:)
/ Mx5100 let me down! #68
Yes it does appear that it is in 4wd. I have that same machine with loaded tires, and it would be hard pressed to lift/move that pallet in 2wd and nothing on the 3ph. Just saying.
/ Mx5100 let me down! #69
I don't pay any attention to videos like that, everybody does them.
/ Mx5100 let me down! #70
You could have lifted the rear end of that Mahindra with a finger. That tractor did not have 10 lbs of down pressure on those rear tires.. Trying to lift the 2400 lbs without rear ballast on any of the tractors was just stupid, like the video.
James K0UA
/ Mx5100 let me down! #71
I used to pay little attention to loaded tires (a real pain when ya get a flat) and rear ballast when using FEL. I learned the hard way and have come to realize it's most important. When ya load the bucket, all the weight is on the front end and weight is taken off the back end, seesaw effect. And on a FWD, the front is doing all the pullin and is much weaker than the back end.
I just had to rebuild the front-end on our old 3750, because of years of FEL work with no weight on the rear and no fluid in the tires. :eek:
/ Mx5100 let me down! #72
I thought thats why weight ballast boxes are sold? I really dont see a problem with the tractor. The problem is the operator not knowing his machines capacity yet and whats needed to get the job done.
/ Mx5100 let me down! #73
General Lee said:
The thing is we don't know the actual weight of the furnace he lifted. The weight was estimated. I do agree tractors should be engineered to lift a full bucket of "common" material, such as loose stone, wet dirt, etc. Sometimes the loader on my L4400 disappoints me and sometimes I'm OK with it. I do think the hydro pressure is set to low and one of these days I'll get it checked. A couple weeks ago I was loading asphalt millings into a small dump truck. On a heaping bucket full, I was unable to lift to max height. I was able to clear the sides of the dump truck to dump but was disappointed it wouldn't lift another foot or so to get to max height. Tractor rear stayed put, I had 1,000 pounds of ballast. I'd like to know how much a bucket full of millings weighs?
My L4400 was a little weak till I set the pressure to spec. Now it does rather well.
/ Mx5100 let me down! #74
I'd like to check the pressure on my MX5100 but don't know how. Because I need to move pallets of landscape brick next week
2008 Toyota Camry Sedan (A61574)
2008 Toyota Camry...
Spray Daddy 400 Gallon 30 Ft Sprayer (A64047)
Spray Daddy 400...
2009 Cummins DGFA-5764071 150kW Standby Diesel Generator (A61572)
2009 Cummins...
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A60429)
2007 CATERPILLAR...
2011 ORTEQ TANK MANIFOLD (A63569)
2011 ORTEQ TANK...
2017 Loat 22ft Tilt Trailer (A59231)
2017 Loat 22ft...
