Agri supply is great! so far
   / Agri supply is great! so far
I can't wait to install the link. Just got a number of projects prior to being able to hunker down and install all the components for the TNT.
Yeah Qstott, I know that plastic you're talking about. It's that 5mil stuff that you have to stab with your utility knife and hope it doesn't slip or break the blade and kill you in the process.
   / Agri supply is great! so far #12
I hit the Agri-Supply in Florence SC when I get a chance, maybe once a year if that. Love that place, could spend all day in there, but seems everytime I get there I'm time limited.:(
   / Agri supply is great! so far #13
On Sunday I ordered a hydraulic top link for my JD 4100 and it shipped today(monday). Awesome! Their price was great. Hope the link works out. Anyone use this one before? HYDRAULIC TOP LINK CATEGORY 1 - Agri Supply
Fast shipping is one thing that always makes me happy about a place:D
I live in Montana and I buy stuff from them because even with the shipping it's significantly cheaper than the the same item available locally. I just bought a clevis from them that was available locally for $35and their price was $18 and with shipping it was like $24. They've always delivered what I ordered and I've been real happy doing business with them.
   / Agri supply is great! so far #14
It came as promised! I was a little dissappointed in the packaging and the cylinder had a little paint worn off it, but it was ok. Here's some pics. It only had a very thin layer of extra small bubble wrap on it. Maybe something they should think about in the future.
I've only bought one thing from them via the Internet and that was a Tee-Jet kit to convert a 3PH sprayer to solenoid controlled valves. The packaging was crap as it looked like they just scrounged the box and components from off the shelf stock, the console's liquid filled gauge was damaged and leaking fluid everywhere, and some non-critical hardware was missing. Agri-Supply made it right by sending me a replacement console and refunding the exorbitant shipping price.
Will I buy from them again? The jury is still out.
   / Agri supply is great! so far #15
I bought a bunch of burners for my homebrew system from them, always great customer service. I wish I was closer to a retail store.
   / Agri supply is great! so far #16
Any update on your experience with this Toplink? I'm thinking of buying the same one.
This one doesn't have any kind of check valves in it, does it? Even if it doesn't, I 'm hoping that I can set my toplink in the desired position and disconnect from my rear remotes (to use them for something else) and the toplink will stay put.
Does anyone see any problem with that idea?
HH
   / Agri supply is great! so far #17
curious too but ill bet it drifts. looks to be the cheapest unit for sale as far as i could find. might be better off spending an extra 50 for one with check valves
   / Agri supply is great! so far #18
I don't see how it can. If both hoses are disconnected (and don't leak :) ) then the fluid can't leave the cylinder, so unless the seals between push and pull leak, it shouldn't move.
At least that's what I would think. That's why I'm hoping someone with firsthand experience with this unit will post. The DPCV units are more money, and more to eventually go wrong. I stick with simpler and cheaper wherever possible.
HH
   / Agri supply is great! so far #19
I bought a set of blanton style hilling disks from them. ASC was great I just wish someone would find a supplier for those hilling disks that used higher grade hardware. The bolts in mine are junk
   / Agri supply is great! so far #20
When I placed my order from Agri-supply I used the catalog..When it came they had doubled the price of both lawnmower tires with no explanation? I had used my ccredit card. They should have let me know or at least called me about it..Their price was then much more than TSC...So use caution on orders..
Electric Golf Cart (A56859)
Electric Golf Cart...
New/Unused CFG Industrial MX15RX Mini Excavator (A57453)
New/Unused CFG...
2020 Toro Pro Sweep Vacuum (A55758)
2020 Toro Pro...
1453 (A57192)
1453 (A57192)
INBOARD DRIVE (A58374)
2011 DRAGON 130BBL VAC TRAILER (A58214)
2011 DRAGON 130BBL...
