Agri supply is great! so far
   / Agri supply is great! so far #21
Hilltop Hillbilly said:
I don't see how it can. If both hoses are disconnected (and don't leak :) ) then the fluid can't leave the cylinder, so unless the seals between push and pull leak, it shouldn't move.
At least that's what I would think. That's why I'm hoping someone with firsthand experience with this unit will post. The DPCV units are more money, and more to eventually go wrong. I stick with simpler and cheaper wherever possible.
HH
It will likely seep past the seals.
   / Agri supply is great! so far #22
HH
dont get me wrong. i would like to buy this unit asap as well if everything checks out. may just bite the bullet and go ahead and get it
   / Agri supply is great! so far #23
buy a couple of ball valves and put them in the hoses
   / Agri supply is great! so far #24
I bought one from them about 5 years ago, and it's still working great. I also bought some hoses for it. I did have to buy some adapters to make the hoses fit the couplers, but it was no problem. I haven't had a problem with creeping. I use it mostly with the box blade, but leave it on all the time. Even with a 7' rear finish mower I haven't had any issues. I'd recomment it.
   / Agri supply is great! so far #25
   / Agri supply is great! so far #26
mjncad said:
Please make sure you get ball valves rated for hydraulic service, and not the ones at Home Depot, et al rated for plumbing service.
Surplus Center
I have this cylinder on my Top-link and I'm happy. Surplus Center - 2X8.25X1.18 CAT I HYD DA TOP LINK CYL
My experience with Surplus Center is that they don't jerk people around on shipping the way Agri-Supply does.
For peice of mind and price, I think that's the one to get. Has lock valve on it. I assume you can remove hoses and it will stay stationary
   / Agri supply is great! so far #27
I haven't disconnected my hoses to find out; but if the DPOCV is functioning correctly, the cylinder shouldn't drift.
2003 INTERNATIONAL 9900I (INOPERABLE) (A58214)
2003 INTERNATIONAL...
Fireplace (A57454)
Fireplace (A57454)
Mini Wood Splitter (A57149)
Mini Wood Splitter...
Le Roi 80-Gallon Air Compressor, 220 Volts (A59076)
Le Roi 80-Gallon...
2015 JOHN DEERE 35G EXCAVATOR (A52709)
2015 JOHN DEERE...
2020 DRAGON ESP...
