Fuel consumption
/ Fuel consumption #1
blucoondawg
Gold Member
Pelican Lake, WI
Kioti DK50SE w/ loader and Woods 90x backhoe, Allis Chalmers C with front snowplow
How are the LS tractors on fuel?
/ Fuel consumption #2
how is are fords on fuel vs hondas?
/ Fuel consumption #3
Mine averaged .75 GPH the only time I ever checked which was right after I got it. That was a combination of grading, finish mowing, bushhogging, and loader work over 8 hours IIRC. Rarely was the tractor at PTO rpm, mostly 1500-2200.
Running it at 2600 and working it blowing snow sucks more fuel, didn't calculate it though.
/ Fuel consumption
What exactly is the point of this comment? That LS are good on fuel as a honda or that LS are like a Ford?
/ Fuel consumption #5
u didnt get it, like what size tractor? u cant compare a 20hp to a 41 hp.
its like u justed asked doess honda have a good mpg ? the first reply is gong to b what model?
my r4041h gets about about the same as the prev post but mine was with roto tiller on full load with the ground being very muddy. As far as brush hogging i would say 1.5 days of 8 hr work.5 gallon tank btw
/ Fuel consumption
I am obviously not trying to compare a 50hp to a 20hp, I mean when comparing a LS to comprable HP of any of the major brands how does it compare? 30hp LS or 40hp LS compared to Mahindra, Deere, Kubota, NH, etc of comprable size while doing comprable tasks. Sort of like a Dodge truck pulling 4,000lb load at 60 mph gets 12 mpg, but a comprable Chev or Ford can pull same load at 60mph and get 15 mpg, these are made up numbers but something like that is what I'm talking about
/ Fuel consumption #8
I have a 3039 and with just aroudn the house kind of stuff (loader work, cutting and the like) I'm getting about 9-10 hrs on a tank.
/ Fuel consumption #9
I think this would be very difficult to compare on here. Every person operates a little different so even if you got Joe and Bob to report on their 40hp kubota and LS respectively, doing the same task, one might be in 3rd/1 at full PTO speed and the other in 2nd/2 at 1900rpm. For the most part the engines should consume about the same amount of fuel for the same work. That said, newer designed engines may get a slight lead on this. How recent are the designs on current tractor engines... beats me but you might be able to dig into it and find out if it is really important to you.
/ Fuel consumption #11
This one was helpful for me ---- Thanks ---- creates a good image for me. More like this would be nice.
/ Fuel consumption
Yes I agree that post was informative, many others on here apparently think its foolish to ask such a question as fuel mileage on a tractor, but at prices approaching $5 its something to consider. I know there are certain brands which can attain pto speed at a lesser engine rpm and certain engines themselves are designed to operate more efficiently than others, guess I will have to look else where for this information, I'm sure its out there.
/ Fuel consumption #13
I can brush hog about 5 acres on less than a 1/2 tank, but never timed it.
/ Fuel consumption #14
About 1/3 of a tank for 5 acres shredding at about 2400 rpm(540 pto) in 3 2 for gear. Did a another 5 at 2400 rpm in 4 2 and burned 1/4 of a tank. Hope this helps. All on level dry ground.
/ Fuel consumption #15
cry me a river.. I put more into my reply than you did on your intital question..
just ribbin ya:D
/ Fuel consumption #16
Nobody said it is foolish, just that it is difficult to compare. There are 100's of tasks a person could put a tractor to and there are dozens of ways to do each one of them. Slow at low rpm, slow at high rpm, quick at low rpm, quick at high rpm, or anywhere in between. I personally haven't timed myself or checked fuel usage for any particular task but on average I would say I tend to use a bit less than a gallon per hour. I do most of my work in the 1800-2200 rpm area which is below PTO speed for my R4047.
BUT, me saying this does not mean the next person will get the same rates of consumption. The next guy could have a heavier or lighter foot on getting to his working area, he may run rpm's faster or slower, in a higher or lower gear in swampy or dry conditions, or with any other different vaiable and he may get 2 hrs per gallon or work at 2 gallons per hour.
IF someone does some significant controls in testing by controlling as many of the variables as possible then you can have an accurate comparison and a gauge by which someone could judge if consumption rates on one tractor make it more worth getting or more worth avoiding.
TractorData.com is one site that is positioned to do this testing but its coverage is very spotty especially on off-brands. I checked 45hp tractors for LS, Kioti, Mahindra, Kubota, and Deere and the Deere was the only one with test results and I'm not sure 3 gallons per hour is accurate or meaningful.
TractorData.com John Deere 4520 tractor tests information
I checked a few more and found Case had one with tests too, at 3.4 ga/hr.
Still meaningless when wondering about LS tractors...
/ Fuel consumption #17
I can say that my 5020 (47hp) gets alot of work done and is comfortable so far dependable when doing it. The fuels consumptions seems good to ME.
Fuel consumption comparisons would be great to know, however without one person performing the same 5-10 hours of work on each tractor compared we will never know.
I think if you can get the work done, in an acceptable amount of time, and the fuel bill is reasonable for YOUR pocket book then it's good fuel consumption.
I think my Duramax pulling my trailer loaded with wheelers and two bull moose on the way back from hunting does great on fuel, but the guy in the Subaru station wagon with an "Obama for president" sticker thinks my fuel economy is criminal. We both have our opinions. So do different tractor owners.
/ Fuel consumption #18
Really? Nice interjection.
/ Fuel consumption #19
With all around use, my R4047 seems to use about 1 gallon per hour.
/ Fuel consumption #20
I quit worrying about fuel cost, it is what it is, and I am not going to sell my tractor and get something else because it supposedly gets .5 gal per hour better fuel economy. My total use per year doesnt justify even checking it.
I suppose that if I were in the major user side of things like the farmer my retired brother in law works part time for and during spring ground breaking season burns $250,000 per month in fuel, there would be some saving in getting the most fuel efficient tractors. The fact that he uses John Deeres might not mean anything though other than he likely gets better lease rates because the swaps them out every year. As everyone said, it is hard to compare tractor fuel economy even when side to side work in the same field doing ground engaging work as soil conditions are never the same from foot to foot. I think the only way that would equal the same would be to put a PTO water pump on one and a flow meter to record the exact number of gallons pumped then hook the other tractor to it and run the same gallons per minute rate and then check the fuel. That would be the same work at the same rate, anything else other than a dynamometer test would be just estimated and a dynamometer test wouldnt run very long without putting excess wear on the dyno.
2015 Case TR320 (A64126)
2015 Case TR320...
2017 FREIGHTLINER CASCADIA 6X2 T/A SLEEPER TRUCK TRACTOR (A59910)
2017 FREIGHTLINER...
24ft. Folding Harrow (A65640)
24ft. Folding...
Unverferth Perfecta II (A64126)
Unverferth...
Drag Tank, Fill Rite 15GPM PUMP  (A62679)
Drag Tank, Fill...
2008 Chrysler Sebring Convertible (A62679)
2008 Chrysler...
