Tractor Sizing Tractor for 20-50 acres
/ Tractor for 20-50 acres #41
Advice on TBN is almost always more more more horsepower etc. Maybe we need a new subforum for "small is beautiful" tractors.
20hp is plenty to get a lot of work done so long as there is no critical time element.
Actually there have been times when I have counseled for smaller tractors. On one occasion my wife went shopping and came back with a smaller tractor than we thought we needed and once we came back with a bigger one.
I didn't come up with this, but use it a lot, "Bigger isn't always better, sometimes it's just bigger."
We have tractors from 23 to 85 HP and each is used regularly, depending on the need.
/ Tractor for 20-50 acres #42
Pretty much the same with guns, trucks, boats, chainsaws, etc... LOL
Nice photos, ya got yourself a very nice little workhorse there!
The size if the trees is about 20 in. diameter and 15' to 20' long, although you could cut it in half.
/ Tractor for 20-50 acres #44
We clamp a cant hook on the big end, lift with the 3-point hitch and drag the logs out. Have a set of forks on the L3750, 45hp that we load them on a trailer with. Easily handles 20-24"+ dia logs. I believe the L3800 would handle logs up to 20" dia and 12' long, maybe larger with no problems, but have not tried it yet.
Like I said earlier, my brother is skidding logs with a small Massey 2300 (23hp), which is very similar to the small B Kubotas, actually it looks like Kubota built the thing.
A 38-50hp tractor will do fine for ya.
/ Tractor for 20-50 acres #45
With a 39HP Tractor I can just pick it up and drive it home. I did need someone standing on the snowblower as it was light in the back end.
/ Tractor for 20-50 acres #46
LOL, might need a pilot car for that wide load.
/ Tractor for 20-50 acres #47
Couple of points -
Look at my link to Woodweb to figure out weights.
For the size tree your talking about 30HP w/ a log arch may do, w/o it won't.
About 15 minutes ago I got back from trying to haul a 12' chunk of oak about 16" DBH.
attachment.php
30 hp Satoh, no can do. Lift it w/ 3 pt, front end leaves the ground. Sure I could load the tires, add weight etc. but it's near the limit. I figured it would be close.
Time to get a better method or bigger tractor.
Buying new or used - Your not to far from Barlow's a great source of used AND new. I bought my Kubota used from Craigslist in 2009, and today could get the same tractor for about $2,000 more.
/ Tractor for 20-50 acres #48
Well Said!
2020 CASE TV450B SKID STEER (A64279)
2020 CASE TV450B...
2007 Chevrolet Express 2500 Cargo Van (A61573)
2007 Chevrolet...
2008 New Holland T2420 (A60462)
2008 New Holland...
2844 (A58376)
2844 (A58376)
2018 CATERPILLAR TL1255D TELESCOPIC FORKLIFT (A62129)
2018 CATERPILLAR...
2014 INTERNATIONAL DURASTER 4300 EXT CAB DUMP TRK (A62130)
2014 INTERNATIONAL...
