L3830 Hazard Flasher Switch
/ L3830 Hazard Flasher Switch #1
stihlman
Southern Illinois
Kubota L3830 HST
The indicator light in the hazard flasher switch on my 3830 doesn't light when the flashers are on. Is there a replaceable bulb or does the switch need to be changed? I think this is the only failure in 6 years of service. I knew I should have bought a Deere! Just kidding! Thanks in advance for any help
Steve
/ L3830 Hazard Flasher Switch #2
Steve
LOL! Yeah should have gone with the Deere.
I would suggest calling the dealer. I'm not sure if it's a seperate bulb or not. I have a feeling it's built into the switch. Mine is still working on my 3830! :thumbsup::laughing:
I have done some research on this since I posted. The bulb is not replaceable and a new switch is $57.00!!! I think I will look around. It is just a lighted push on/push off switch. Seems high to me, must have green paint on it somewhere
Steve
/ L3830 Hazard Flasher Switch #4
Have taken many switches apart over the years to clean contacts, grease and reassemble. Grain of wheat lamps are available on line at Mouser and Digi Key. You could replace with an LED and dropping resistor if you are real good.
Simple way is to drill hole next and put a pilot light from Radio Shack next to it.
David Kb7uns
I am sure I will just bite the bullet and buy the Kubota switch. I was just shocked by the price. Thanks for the advice anyway
Steve
/ L3830 Hazard Flasher Switch #6
On my L3830, the light illuminates only when the headlights are turned on. It doesn't light when the headlights are off and the hazard is on.
2022 EZ-GO ELITE...
Kubota SVL 75-2 (A60462)
Kubota SVL 75-2...
2026 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2026 SDLANCH...
2014 Mercedes Benz CLA 250 Sedan (A61574)
2014 Mercedes Benz...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2021 CAT 289D3 (A60462)
2021 CAT 289D3...
