Moving up - L3240 or L3940
/ Moving up - L3240 or L3940 #1
RTII
Gold Member
Brazos and Robertson Counties, Texas
Kubota GL 3940, Kubota M5 111
Hi All,
Been a while since I've posted but now once again would like opinions and experiences to help with a decision on which model to go with. At the moment I have a BX2660 with attachments (as per my sig line) which was exactly the right tractor for the need to work my original 4 acres around the house. I've since purchased another 10 acres and have decided a tractor upgrade would make my life easier as the BX just doesn't have the capacity for me to maintain 14 acres efficiently. It'll get most of the jobs done but I'd like to cut some time off of most of the work.
The new tractor would be used mainly to bush hog, move brush and downed trees, landscaping, etc.
The implements I'm looking to add would be FEL with quick attach bucket, qa grapple, 5 or 6 foot shredder, possibly a box blade.
So to the questions:
  1. I'm leaning toward the smaller 3240 as I've been amazed at what the bx can do with the horspower it's got. It's taught me that max horsepower, while nice, may not be required. This would save me some money that could be put towards the implements. I've seen other threads where the concensous was to get the heavy FEL and loader. Would the smaller tractor have any problems using this set up to it's fullest capacity?
  2. What's the practical difference between the round back and square back buckets?
  3. Are there any "issues" with either of these tractors I should be aware of going in?
    1. Shredder size 5' or 6'?
  4. This one is probably the most subjective but do you think these tractor choices are a good fit for my purposes?
Thanks in advance for any input you guys can give.
/ Moving up - L3240 or L3940 #2
I had a L3130(replaced by the L3240),very nice all a round tractor;they are a 3cylinder diesel.The L3940 is a four cylinder and larger framed tractor,but the sweet spot in the lineup IMHO.In between the L3540(same frame as L3240 and a three cylinder).I purchased a L4240 for the larger 854 loader.If you are not going to add a back-hoe..the L3240 will do everything you need.Stick with the five ft.shedder,I don't know the difference in price on the buckets but would recommend the HD round-back and the larger loader.Have the rear tires filled.
Thanks birdman,
Good thought on filling the rear tires. I'll do it. Does the round back bucket have more capacity than the square back? Would the 72" bucket be a good fit for the tractor or would the 66" be more appropriate? Can anyone tell me what the 4in1 bucket refers to?
/ Moving up - L3240 or L3940 #4
Well I always believe that the best route is to buy the max HP in the size of tractor you like. I also think that it is poor economy to not get the toughest loader you can get too. A little ballast and you will be amazed how much more capable the bigger loader is.:D
My general thoughts as well. I don't think I would regret going with the bigger tractor but trying to balance need and budget makes me lean towards the 3240. That 3940 sure is a fine tractor though!
As a thought, any reason other than size of cut I couldn't keep my 48" shredder and used it behind one of these tractors. Maybe try it out for a while and see if it works for me. Lots of trees to mow around and maybe the smaller shredder would have an advantage?
/ Moving up - L3240 or L3940 #7
Sure, you can do it, but I have a 48" cutter for my BX2660 and there is no way I would use it on anything above a B Series.
/ Moving up - L3240 or L3940 #9
Because.....??
Because I would bend the snot out of it.:eek:
I see no reason to get a bigger tractor to run the same size equipment, but that's just me.
I run a 4' on our BX, 6' on the 5030 and 10' on the 8540.
/ Moving up - L3240 or L3940 #10
I used a five ft.shedder on my L3130 and it was a good fit,also use it on my L4240..I could use a six ft. but until this one breaks beyond repair I will continue to use it.The four won't cover your tracks (with a L3240) but would be useable I would think.
I never used a 4n1 bucket but it would require a third function on the front to work.They can open to grasp/scrape ect.A grapple or a thumb on the bucket would also require a third function.For my use I added a thumb to my bucket and a tooth-bar,works for me.
I see what you mean - brain fart on my part. :mur: Whole idea is supposed to get more work done in less time.
Gotcha on the 4in1. Thanks for explaining but doesn't sound like what I want. I do plan on getting the third function for the grapple. The thumb looks good on your bucket!
/ Moving up - L3240 or L3940 #13
I think the question I would ask myself is how much acreage do you plan to use the brush hog on. If your goal is to cut the time doing some of the tasks then does it really make much sense using an undersized shredder?
That being said I would think about a 6'er. It's going to save the most time and it'll cover the width of the tractor. Then I would try to find reasons, like you were saying working around small trees, that a smaller one would work better. Once I made that choice I would then look at the HP needed, the 3240 will be a little small for a 6' cutter.
I don't think the 3240 is physically much smaller than the 3940. Sit on the two and decide for yourself. I think the tractor would be fine size wise but I would get the HST as it's very controllable. It could be a little large if your landscaping duties happen to be in narrow locations. But chances are it'll feel big at first but once you get some seat time it'll fell right.
/ Moving up - L3240 or L3940 #14
Make sure the L3240 can handle a 6' cutter. To save time and cover tracks trimming to the edge, I think you will want the 6' cutter. I run a 6' behind my L3940, and in everything except 6' tall stuff, it runs with power to spare. The 6' cutter is heavy, makes my front end light, but managable, without FEL on. Philip.
/ Moving up - L3240 or L3940 #15
For my two cents worth, before I purchased I rented a L3240 for a week from our local Kubota dealer. That experience convinced me that I needed the L3940 for the 70 acres and for the work I am doing.
I have the skid steer quick attach with a third function and a grapple bucket which I love with all my heart. Also have a 6 ft box blade and 6 ft shredder and there are times I wish I had a larger one. It is amazing how small a 6 ft shredder can feel and how large the fields can seem to be towards the end of a long day.
Water with sealer in all tires, sun shade and a few other things like a disk harrow, etc and life is good with the little Kubota.
280 hours in two years and I still love her.
Problem is I just moved her over to the 200 acre ranch and she is a bit out of her depth so to speak... We will take it slow and she will be fine.
Good luck, you really can't go wrong.
Mike
Yesterday went and kicked the tires and test drove both tractors. End result was made a deal to purchase the L3940. HST+, FEL, Third function and grapple, 6' shredder, filled R4 tires. A lot to like about both tractors and I think either would have performed the work I've envisioned for the near future.
A couple of things swayed me toward the 3940 over the 3240 besides the obvious HP and capacity increase. One, although dimensionally only a few inches longer and a few inches taller, the ride seemed noticeably smoother. I also felt the 4 cylinder engine was quieter and smoother than the 3 cylinder on the 3240. I suppose there will be a fuel penalty for the extra cylinder and horsepower but I'll never notice since never having owned the 3249 right?:D
Things I really liked -
  1. HST+. This system is so versatile yet easy to use. I can see a lot of different applications that will take advantage of it's capabilities.
  2. Position control on the three point. Way better than the 1/4" control on my BX.
  3. Telescoping lower arms on the three point.
  4. Pleasantly surprised at the nimbleness for size. I thought I was going to have to deal with clumsiness (for lack of better word) by moving up to a much bigger tractor than my BX but after driving this I don't see a problem at all.
Well the wait begins. Tires on the way and third function valve on back order. Gonna be a long week.
/ Moving up - L3240 or L3940 #17
Congrats on the new tractor. The wait is going to be the hardest part. I've been waiting 24 days now for my 5240 and it is brutal, especially with the nice weather we are going to have this week.
/ Moving up - L3240 or L3940 #18
Congratulations, I believe you will be very happy with your selection.
/ Moving up - L3240 or L3940 #19
That is exciting news, I am sure it will be worth the wait.
A little FYI on the Kubota third function. When I received my tractor from the dealer every hydrolith line they touched leaked and the third function was horribly sticky. If you clicked open it would stick in the open position, if you selected close it would stick on the closed position. You had to keep playing with it to get it unstuck.
That tractor went back to the dealer in Eglin 6 times with no relief to the problem. Switched dealers to one a bit closer in Marble Falls and they tried 4 times. Finally they replaced the unit and it works better but still isn稚 perfect. It also leaks pressure so as you haul from point A to point B you have to keep tapping the close button, hoping it won稚 stick.
They messed with it and the lines so many times that everything under there has a weep about it so it gets a bit nasty and I have to clean it ever few weeks.
With all that said I would never own a tractor without a third function because the grapple makes everything especially cedar tree removal a hundred times easier.
I do a lot of cutting and dropping the tree limbs with the chainsaw then go in and grab up the tree parts and drop into the burn pile. Works like a champ, what a force multiplier.
My point is check it out before you leave the shop. Make sure you run the engine speed up to where you will be grappling (about 1,400 RMP for me) and exercise the darn third function.
There are many posts about this so I am sure there is a basic flaw with the Kubota unit.
I still love it, that is my ONLY complaint
Good luck, Mike
Thanks guys. I'm sure it'll be worth the wait.
A little FYI on the Kubota third function. When I received my tractor from the dealer every hydrolith line they touched leaked and the third function was horribly sticky. If you clicked open it would stick in the open position, if you selected close it would stick on the closed position. You had to keep playing with it to get it unstuck.....
Good point Mike. I knew from searches on here that this could be a problem. A friend of mine a couple of counties over has the third function on his tractor and doesn't have a problem with it. He's had it approx 4-5 months so that gives me hope that not all of these act up. Also my dealer said they have had these valves on order since Feb and believe they are waiting on the manufacturer. So the optimist in me is hoping maybe Kubota is addressing the issue and has stopped delivering faulty valves and new/improved valves are on the way. I'll let you know how that fantasy goes
THIS WILL BE A LIVE VIRTUAL ONLINE AUCTION! (A63109)
THIS WILL BE A...
Hydraulic rail grinder (A61307)
Hydraulic rail...
2018 FREIGHTLINER CASCADIA 125 6X4 T/A DAY CAB TRUCK TRACTOR (A59910)
2018 FREIGHTLINER...
2007 International 8600 Parts Truck (A63118)
2007 International...
JAYCO JAY FLIGHT BUMPER OULL TRAVEL TRAILER (A63569)
JAYCO JAY FLIGHT...
TRUCKRAFT HYD PUMP (A63290)
TRUCKRAFT HYD PUMP...
