deisel won't stay running when warm
/ deisel won't stay running when warm #1
dnodolf
my satoh loses power after the engine warms up. just put new rings and injector pump in it. acts like it is under load and shuts down. Any ideas
thanks
/ deisel won't stay running when warm #2
thanks
When you say it acts like its under load does it start putting black smoke out of the exhaust?
Could it be that the fuel filter is partially plugged off?
How about the mechanical fuel pump, is it supplying enough fuel?
Could you be a little more descriptive of how it acts?
Do you have it revved when it starts to power out?
I have seen fuel starvation cause a shutdown like this but more details would help in a diagnosis.:thumbsup:
/ deisel won't stay running when warm #3
Filter sounds likely. Maybe crud in a fuel line?
I once had a piece of debris in a gas tank that was just floating around near the bottom. If I ran the engine flat out for any period of time, the increased suction would draw the debris against the outlet port, blocking it and causing the engine to stumble. It would recover once it was at lower revs and the suction was reduced enough to release the debris. Drove me crazy for months until my fuel gage sending unit started going and the fuel gage would go from 3/4 tank to empty in a heartbeat. Found the debris when I drained the tank and R&R'd the sending unit. Suspect the debris came from the sending unit. Bust out the flashlight and have a look in your tank - maybe a cheap & easy one to fix!
2025 PJ CC162 T/A 16FT EQUIPMENT TRAILER (A59912)
2025 PJ CC162 T/A...
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60352)
2020 Freightliner...
2017 Ford F-550 4x4 Ext. Cab Auto Crane 4004EH 2 Ton Crane Service Truck (A61573)
2017 Ford F-550...
2020 ASV RT65 (A60462)
KMC 3pt 6 Row Vine Lifter (A64119)
KMC 3pt 6 Row Vine...
2024 JCB 35Z (A60462)
