engine knock
/ engine knock #1
hernando
tennessee
dk 4510 kioti and a 450 case track loader
i have a older gas john deere in has a knock in the engine i thought it was a rod but i was told it was carbon build up...how do you tell the difference between the two ? it does not make the knocking sound when under a load....using the loader ect....but when just driving it across a field it starts knocking...... any ideas ??? i dont want to do a rebuild unless i have too...thanks for the help bruce
/ engine knock #2
There was a recent post by someone who used Seafoam for carbon.
/ engine knock
ok thanks i will check on that bruce
/ engine knock #4
You can also feed in a gallon of water (in a metered slow fashion!) to a hot engine and it will clean off the carbon. I use a small diameter hose to a vacuum port. Keep rpms to PTO levels. It will cool the engine so you need to keep a watch on temperatures to keep the engine hot. It works better when hot.
/ engine knock
changed the timing ....it helped alot.. thanks for the help bruce
/ engine knock #6
Check the intial timing and the advance function.
/ engine knock #7
Hello guys I have a problem with my tractor knocking and blowing oil out of the dip stick tube. Any advice will be appreciated TIA.
2016 Boxer 700HDX Compact Skid Steer (A63109)
2016 Boxer 700HDX...
2021 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A59230)
2021 Chevrolet...
UNUSED CFG INDUSTRIAL MH12RX MINI EXCAVATOR (A62130)
UNUSED CFG...
New/Unused Electric 3-Wheeler (A61166)
New/Unused...
UNUSED WOLVERINE TL-12-72W 72" HYD TILLER (A62131)
UNUSED WOLVERINE...
UNUSED WOLVERINE ADB-13-1218R HYD AUGER (A62131)
UNUSED WOLVERINE...
