Putting eyes in cable...
/ Putting eyes in cable... #1
JimS
I have several sections of 1/2" cable I use to pull down trees, etc. I do a Molly Hogan (aka Flemish Eye) and put one cable clamp on the tail. Works great and if the clamp is checked for tightness from time to time they are almost as strong as the cable itself. My question is what to do about the cut end. Over time they fray and make a mess of sharp wires. I wrapped them with tape but that didn't last long. I suppose I could bind the end (think there is actually a term for this) with cord. Looking for ideas. Have even thought of using some heavy plastic heat shrinkable tubing.
/ Putting eyes in cable... #2
Maybe copper tubing crimped or soldered on the end.
I've always wanted to try the "spelter socket" ends but never ran across the materials.
Bruce
/ Putting eyes in cable... #3
What about ox/ace torch with welding tip, and melting the ends into a ball? would that work?
James K0UA
/ Putting eyes in cable... #7
yep a minute late...:) I have never done it. but seemed like a good idea to me..
James K0UA
/ Putting eyes in cable... #9
You could learn to do real splicing.
In this way the ropes don't come apart and over time the sprags end up inside the rope.
http://www.worksafebc.com/publications/health_and_safety/by_topic/assets/pdf/splicing.pdf
there are other manuals on splicing on line
Manual on splicing - Google Search
Put a big enough eye splice (or Flemish Eye) on the cut end to pass your Molly Hogan through.
Then you can snare your tree with the business end and have a quick hitch to a ball, hook or D-ring on the pulling end.
I might try the copper crimp. The torch seems like the best idea but don't have a torch. Might get a friend to do it.
The real splicing links are very interesting. I remember my dad who was a logger in his early years talking about the old timers splicing line that would go through pulleys. Might try it sometime when I have some time.
The big eye to loop around has a good chance to kink the cable and weaken it, IMHO. I prefer to wrap the cable a couple times around the tree and secure the end with a clevis. With the friction of the wraps the end has very little tension and the larger clevis pin has less chance of kinking the line.
/ Putting eyes in cable... #11
I wrapped them with tape but that didn't last long. I suppose I could bind the end (think there is actually a term for this)...
It's called 'whipping' the ends.
/ Putting eyes in cable... #12
I have tinned copper strand wires before and have brazed galvanized conduit - I would assume you could easily braze the galvanized wire ends.
If you attempt this - just remember when you apply high heat (braze / weld) galvanized metal - it produces toxic fumes. Really need a respirator or do it outside upwind.
Learning to splice would probably be the best method.
/ Putting eyes in cable... #13
I'd go with splicing if I had the cable, the time, and a good pair of gloves & safety glasses. Not sure if there's a back splice for cable, but that would finish the free end. I've done plenty of splices in 3 strand rope and a few in double weave synthetics. You get a very strong and reliable joining.
PORTA POTTY (A67714)
WELDING TABLE WITH VISE (A68842)
WELDING TABLE WITH...
2002 Bombardier Evinrude 90HP Outboard Boat Motor. (A66738)
2002 Bombardier...
HOSES (A68842)
HOSES (A68842)
23.1-26 Tires - Set of 2 (A68134)
23.1-26 Tires -...
CAT D5N Winch (A68134)
