Water in oil 327cu/in Chevy
   / Water in oil 327cu/in Chevy
timswi said:
Did you let the car get to 180 and run for a while before you drained the oil?
No, the first time i noticed it i shut it down and changed the oil. I have ran it twice including today on the new oil since finding water the first time. Both times it was ran to operating temp and allowed to run for about 15 minutes or so. Is there a product that i can add to the oil that will help "dry" or "clean" the motor?
   / Water in oil 327cu/in Chevy #92
IMHO I don't think after the oil change there would be enough moisture present to cause the milky dipstick you are seeing! BUT that said I've been wrong before! Hope it's that simple! :thumbsup:
   / Water in oil 327cu/in Chevy #93
Not that I know of, but can you just putter the car around for a half hour under temp and see what happens?...I've seen this before, but you are on a borderline of something..Hopefully nothing and that's one of the options...If you aren't loosing coolant, the h2o is coming from somewhere..Your location adds variables that I don't generally have..High humidity and rapid temp changes. That's adds a ton of mosture to anything steel...Just thinking out loud.
Did you try pressurizing the rad and check for a leakdown?
The car is not road legal yet. I usually idle it up to 1500 rpms and let it run. No, i have not tried a rad pressue test yet. I may stop at the parts house tomorrow and pick up the necessary equipment to do so. This is bugging me and i would like to rectify it soon. Or build a nice 396...454...427...:)
Did you try pressurizing the rad and check for a leakdown?[/
What is needed for a pressure test?
   / Water in oil 327cu/in Chevy #97
There's a pump for that although you may have to go to something beyond AutoZone to get it.
Well it looks as if I will be pulling the motor. The rad is down about a quart again and there is water in the oil. Ive decided to pull it and send it to a machine shop to be gone through. Hopefully it is a head and not the block. Where ever the leak is, it is internal. No water on the floor. If it can be fixed, i will reassemble it with the bigger cam and better heads i mentioned earlier. A little bummed as it has a lot of sentmental value. That is the main reason i am trying to fix it.
   / Water in oil 327cu/in Chevy #99
Why not pop the heads off and take a look before you pull the motor you my see a bad head gasket if that's all it is put a new set on and run it??
That is the plan. I should have been a little clearer. If the problem is not in the intake or heads, ill pull it and send it off.
Mitsubishi FG35 Forklift - 8,000lb Lift Capacity, LP Gas (A52128)
Mitsubishi FG35...
2016 Nissan NV200 Cargo Van (A50323)
2016 Nissan NV200...
2019 INTERNATIONAL 4300 26FT CDL REQUIRED BOX TRUCK (A51222)
2019 INTERNATIONAL...
1993 Mono Dump Trailer (A50514)
1993 Mono Dump...
CATERPILLAR 299D3 SKID STEER (A51242)
CATERPILLAR 299D3...
2015 ISUZU NPR 16FT BOX TRUCK (A51219)
2015 ISUZU NPR...
