John Deere 70 - Pull to Electric Start?
/ John Deere 70 - Pull to Electric Start? #1
rgs03833
Haverhill, MA
MTD 660, 690 - John Deere 60, 70, 108, 2 of 111, 111h, STX38
Hi guys....
I recently purchased a John Deere 70 (Tecumseh VH70 ???). It's OK, I just like the OLD look... Anyway, I took the Engine apart... Do my Magic and now it Starts with 1st or 2nd Pull even weather are in the 25- 30's...
Anyway., I wanted to see if any of you guys have turned a Pull Start Engines to an Electric Start?
I have been researching around on YouTube for Videos, I did do a Cheesy Drill Starter... It works, LOL... I just don't want to damage anything since the Torch is high. It's only a 7HP Engine so it's OK, but just incase...
See Sample (NOT MINE):
[ame=http://www.youtube.com/watch?v=2kHsmpEOSQ0&feature=related]John Deere 14SE BBC Self Propelled Electric Start Lawnmower - YouTube[/ame]
I know, you guys gonna tell me that since it Starts on 1st or 2nd pull why bother.... Well, I just wanted to sit down and press a Button and it Starts, rather than lift the Hood, Pull the Cord, then shut the Hood and then sit back down.... Kinda inconvenience if you asked me...
I don't know if any of you guys have done it before... Maybe you guys can give me some Tips... Anything will / would help.... Although I know I'm gonna have to come up with my own invetion.
My Flywheel do NOT have the Gears... I was thinking buying a Flywheel with Gears on it and then add an Electric Starter to it. My Engine is a 7HP Tecumseh Vertical... I don't know how old it is because the previous Owner sprayed paint everything black as you can see in the Pix.... :(
Would most of the Tecumseh Flywheels will Fit or made the same? Well at least where the hole where you put down the Shaft / Coil / Magneto? I have enclosed some pix, and the Example of a Flywheel I found on Ebay with Gears (Last Image)... Since mine doesn't have Gears... Maybe this will work?
Please take a look and give me some advice or input... Anything would be greatly appreciated !!!
Thank you !!!
/ John Deere 70 - Pull to Electric Start? #2
The damage you will do, starting like the video, will be to the electric drill you are using. When the engine starts, it has a higher rpm than the drill. As you noticed, it wrenched a bit from your hand when the engine started. (certainly took longer than one pull on a cord :) ).
You might find a starter that will match up to the ring gear on the flywheel, but you will notice that there is a method to disengage the starter when the motor fires up.
Enjoy the experimentation and rigging. Should be fun and a learning experience.
Hi,
That VID on Youtube is not mine :( Also, that's a Push Lawn Mower not a Lawn Tractor... LNFAO :D:D:D:D
It's an example of what I made, lol. Put your glasses on,hehehehehe
Yah, the RPM is a lot higher... That's why I want a different Flywheel, mine doesn't have Gears... I would have done it by now if it has Gears...
CORRECTIONS: It's a TECUMSEH H70 ENGINE on my JD 70.
I found a few Flywheels on ebay, but affraid it won't lined up with my Coil / Magneto :(
Searching still.... LOL
/ John Deere 70 - Pull to Electric Start? #4
That I knew and I don't need glasses :), and wish you good luck in your search.
2000 Mack CH613 Dump Truck (A59213)
2000 Mack CH613...
2019 FREIGHTLINER CASCADIA 126 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2019 FREIGHTLINER...
SCAN TO RECEIVE TEXT UPDATES (A63745)
SCAN TO RECEIVE...
Wacker Neuson EZ26 (A60462)
Wacker Neuson EZ26...
2018 Regal 29OBX 29ft Boat with 34ft T/A Boat Trailer (A61569)
2018 Regal 29OBX...
2023 Kubota Z412KW Zero-Turn Mower with 3-Bag Bagger System (A63118)
2023 Kubota Z412KW...
