UPDATE: Is Tractor Weight Important?
/ UPDATE: Is Tractor Weight Important? #21
Nice tractor! Enjoy!
/ UPDATE: Is Tractor Weight Important? #22
I am attaching a photo with the knob circled in yellow. Kubota refers to this as the "3-point hitch lowering speed knob." According to the manual, it has three settings:fast, slow and lock.
The salesman adjusted it with the Bushog SQ160 on the back. It transformed the jerky lowering of the attachment to a smooth motion. I have been using it on the property and have had no further issue.
Sounds like we are talking about the same knob....not sure why it didn't work for you.
Oh my new friend.. if it was only that simple..:):) Please bear with us old curmudgeons. If you try to raise the 3pt hitch slowly with an implement on the back is where the problem comes from. Now that said, all of the tractors are not equal. some are much worse than others...You can read for days on this subject. here is a little info. Hope yours does not have this problem.
http://www.tractorbynet.com/forums/kubota-owning-operating/213762-jerky-lseries-3pt-hitch-fixed.html
http://www.tractorbynet.com/forums/...ng/233308-l3400-3-point-hitch-adjustment.html
James K0UA
/ UPDATE: Is Tractor Weight Important? #23
Congrats!! And I wouldn't let some rain keep me off it, that's why we have rain gear.
/ UPDATE: Is Tractor Weight Important? #24
The problem in those models seems to be jerkiness in slow lifting, not lowering, the knob under seat only affects lowering.
:thumbsup::thumbsup:
James K0UA
/ UPDATE: Is Tractor Weight Important? #25
I agree with TripleR on the function of knob under seat. I'm not sure if the new models, of the L's have the same issues as the previous models did. I know the jerky three point hitch is not issue with the Grand L's.
DevilDog
/ UPDATE: Is Tractor Weight Important? #26
I just found this on You Tube.
[ame=http://www.youtube.com/watch?v=sPUnz3SmOgQ]Kubota L3800 jerky 3 point hitch fixed - YouTube[/ame]
[ame=http://www.youtube.com/watch?v=jSTJrL6AwYg]Kubota L3700SU Jerky 3pt Hitch - YouTube[/ame]
/ UPDATE: Is Tractor Weight Important? #27
Congrats on the new tractor. Just remember, help is on here all the time and all you have to do is ask. :thumbsup:
/ UPDATE: Is Tractor Weight Important? #28
New2NC, If you like the way your tractor works and the 3pt hitch suits you, don't worry about all this banter about jerky 3pt hitches. I'm convinced that many people with this problem never even worried about it till they read it on here. Enjoy your new tractor, looks like a good choice to me. :thumbsup:
/ UPDATE: Is Tractor Weight Important? #29
Tractor weight is important when pulling heavy loads or lifting with the FEL. If you have your tires filled, and use a ballast when lifting heavy loads you should be fine. Just remember to keep heavy loads close to the ground when transporting and avoid side hill travel with a load on the FEL. The lower a full bucket is to the ground when moving the easier it is to control the machine. If you feel the wheels coming up, drop that bucket on the ground and let the tires come down. The closer the bucket is to the ground the faster you can get it under control.
NOTE: Ignore my avatar that was a small stump I was lowering on to a fire.
/ UPDATE: Is Tractor Weight Important? #30
While I agree with everything you said above, look at your avatar. You need to practice what you preach.:):laughing:
/ UPDATE: Is Tractor Weight Important? #32
Come on, guys. He said to ignore his avatar!
/ UPDATE: Is Tractor Weight Important? #33
My apologies to brewdog, I was just kidding you. No need to change your avatar really, that was a good pic. I obviously offended him enough to send me a pm this morning.
Heck, if there was really anything wrong with raising the fel up then the manufacturers would limit their travel. Please lighten up.
2025 IRET13 Electric Tricycle (A64194)
2025 IRET13...
2019 HYUNDAI V12530152-AJS 53' 102" T/A VAN TRAILER (A59912)
2019 HYUNDAI...
2019 International LT625 Sleeper 48" (A62613)
2019 International...
2022 Schulte SMR-800 Multi Rake Landscape Windrower (A63688)
2022 Schulte...
2017 Ford F-150 Pickup Truck (A61573)
2017 Ford F-150...
2018 F550 Bucket Truck (A63689)
2018 F550 Bucket...
