Hydraulic Accumulator System Design?
/ Hydraulic Accumulator System Design? #1
kdlklm
Saskatchewan, Canada
Kubota BX1830
I'm designing a machine that has a hydraulic lowering system, I was thinking about incorporating some sort of accumulator system to absorb some of the shock when the machine is being driven.
I was looking for someone who might have done something like this before, and might have some advice.
I don't really want to go to an air system, because the machine is going to be completely hydraulic. And I don't really want to start mix-and-match systems.
/ Hydraulic Accumulator System Design? #2
I've seen hydraulic accumulators, but I have no idea how they work.
But, I'm fully intrigued by this machine that you are building. What is it?
/ Hydraulic Accumulator System Design? #3
If you don't want "air" type system then you will have to go with some form of spring loaded or other mechanical device since hydraulic accumulators are pre-charged with nitrogen.
These can be tricky to design or incorporate and usually require special plumbing and considerations for safety lock outs / bleed downs.
Wilkes McLean (spelling) and or Nacol used to have a site for sizing accumulators. Not sure if they still do or not.
/ Hydraulic Accumulator System Design? #4
The job of an accumulator is to store energy or absorb shock loads AT WORK
and to reduce pulsation therefore dampening the pressure spike to a manageable pressure.
If you are designing an articulating steering system you need a cushion valve in the steering circuit.
A far as the need to install an accumulator to do what you are describing it can be done BUT its a waste of money as the accumulator will increase the amount of bounce if it is installed in a double acting hydraulic system.
/ Hydraulic Accumulator System Design? #5
Is the intent to store energy or dampen surge pressures? Either way with an accumulator you will be storing some energy. If you choose a very small accumulator precharged to system working pressure it would dampen w/o storing much energy. Cood be good for what you want. You could bias the in/out flow rate with a custom check valve to improve system properties.
larry
I've posted several topics on this machine before, it's designed for a person in a wheelchair to drive from the front with the joystick.
When I referred to not wanting to use air, I meant that I don't want to have a compressor on the system to rejuvenate air, like you have to with an airbag system.
/ Hydraulic Accumulator System Design? #8
Oooohh! The wheelchair ATV. Of course. How's that project coming. Last I followed it you were still in the design phase. Are you building yet?
Yes we have started building the frame of the machine, and articulated steering. Still lots of issues to work out, but it's coming along slowly. I've got lots of photos on my website, if you're interested.
ATV
/ Hydraulic Accumulator System Design? #10
Is this for ride control? If yes, several companies are already using this concept for construction and ag equipment. Most of them have a solenoid operated valve so you can choose when to use this feature and when you want to lock it out.
Any idea on what pressure you are going to be working with? Reason I ask is that I think there are some regulations on hydraulic pressure allowed next to people in an enclosed or restrained environment.
Roy
Roy
Yes it is for ride control, I want to make it a little bit smoother, could you give me an example of a company that is using this. I would like to see what exactly they're using. The PSI will be fairly low, probably below 1500.
/ Hydraulic Accumulator System Design? #12
John Deere has a Hydraulic front axle suspension system on some of their tractors. They call it Triple-Link-Suspension (TLS) 6030 & 7030 series have availible. Uses hydraulic cylinders and accumulators (3)
John Deere also has a loader suspension system (LSS). It uses an accumulator with an valve to shut off system teed into the line to the loader lift cylinders. Lift side of the cylinders.
/ Hydraulic Accumulator System Design? #13
JCB & I believe BobCat have similar systems to what JD is using.
/ Hydraulic Accumulator System Design? #14
There is no compressor required, you just precharge the accumulator with air/nitrogen and unless there is a leak, there is no loss of pneumatic pressure.
/ Hydraulic Accumulator System Design? #15
Very interesting! I think youll need to use a small accumulator for each wheel to in effect make a tunable spring damper system. They are a bit more expensive than I thot but McMcarr is not the cheap supplier. May not have to go with the top pick bladder style.
McMaster-Carr
Over/ Under Oven (A60352)
Over/ Under Oven...
2016 Buick Regal Sedan (A61569)
2016 Buick Regal...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2013 Peterbilt 365 IMT 40/275K6 9.5 Ton Knuckleboom Crane Truck (A60352)
2013 Peterbilt 365...
Bell 1600 Gallon Nurse Trailer (A63118)
Bell 1600 Gallon...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A60460)
2019 Freightliner...
