BX22 wont start
/ BX22 wont start #1
copperhead1967
Gold Member
greensburg PA
kubota BX22, Cub ZForce S 48 inch deck
OK, Used the tractor last week in 40 degree weather. Hauled some firewood and drug the gravel drive a bit with the rake since it was above freezing.No problems starting and ran for about a hour.
When I parked the tractor I tried to start back up and curl the bucket down like I normally store it. No click, no fuel pump buzz, nothing. Left her sit until today.
Todays its in the low 20's .Went out and tried to start, no start, no fuel pump buzz, nothing still. I put jumper cables on it, nothing after about 5 minutes. After 10 minutes it tried to turn over but was real weak.
I got the volt meter out and it showed 14.7 v with jump vehicle still hooked up. Pulled off jumpers and to my surprise it showed 12.5V on tractor battery.
Hooked jumpers back up for another 20 minutes. Still sluggish cranking and no start.
Removed POS wire off battery and hooked jumper cable directly up to it, thinking bad battery/shorted cell.
Jumper cable started to smoke slightly at tractor POS clamp after several start attemps. It's acting like it has about half the regular cranking.
Swapped out jumper cables as they where older set, then looked at POS clamp and saw some green corrosion behind the clamp on the copper wire.
I then took off hood bonnet and hooked directly up to starter POS and frame bolt with jumper cables. I still have POS cable off tractor battery. Still half cranking power.
Checked glow plugs and have 12.5v in glow plug key position. Tried to OHM out plug rail to ground but meter seems to be cold or have weak 9v battery. Gave weird reading. 1.1.8.1 or something goofy.
On to fuel, since side bonnet is off I disconnected fuel line on the output side of 2nd fuel filter by engine. Cranked for a second and fuel is pumping good.
My BX doesn't have any seat safety switch, never did. Just the Nuetral/drive safety switch and when that acts up there is no power to anything.
I'm out of things to check. Any ideas what to look at next?
Question about the glow plugs are they supposed to shut off after a certain time? Mine never have, just time them by counting to 30 or so depending on how cold it is. Thanks for any suggestions in advance and enduring the long read.
/ BX22 wont start #2
The only things of significance, it seems, is:
>It will turn over with a jump. That rules out all safety shut offs.
>The fact that hooking directly to the starter from a good/running jump source (tractor battery disconnected) still results in a slow crank.
That pretty much leave the only problem as the starter or the solenoid. Try tapping on the starter with a hammer like we used to do in the old days.
Others have had the issue you have. Do a search for more suggestions.
http://www.tractorbynet.com/forums/kubota-owning-operating/211636-bx-2200-wont-start.html
/ BX22 wont start
Thanks GW,
I didnt get back to it as a snow storm blew in but I did print the electrical diagram. Seems to me the old "bump the starter" was when it was stuck and wouldn't crank at all but I'll give it a shot in the AM. Is there a way to bypass the solenoid with a jumper. Trying to eliminate wires on the the diagram now.
Tractor was just torn down this past summer so I'm not ruling out something is pinched and shorted somewhere in the harness.:mur:
/ BX22 wont start #4
The solenoid's only purpose is to advance the gears to engage the flywheel. The solenoid must be OK since it will engage and turn the engine.
So, if you just hook up a battery to the starter only it will spin merrily if it is fine.
At least that will give you information that the starter works when it is not under load.
My suggestion is to take out the starter/solenoid and see if it will work correctly on the workbench. Only two bolts/nuts if I recall correctly.
Another option is to take the part to one of the automobile stores that will test it for free. Who knows, they may have something that will fix it or replace it. Kragen/O'Reilly auto parts does that kind of thing out west. Maybe you could call around to find one in PA.
/ BX22 wont start #6
So, you bypassed the positive battery cable. How about bypassing the negative battery cable? Loose or corroded wires will carry voltage but not amperage.
/ BX22 wont start #7
Was engine removed when tractor was torn down? How good is the engine to frame connection? You connected negative jumper to frame try negative to block with good set of jumpers. Sounds like ground path to engine block/frame has paint or high resistance. Fuel pump body components good with jumper ground to frame and then may loose them when ground to block. When removing battery you ask a lot out of jumpers that is why they have to be a good set (Thick Wire with small teeth for contact - More contact area). Put a 9volt in meter and check block to frame resistance with ohm meter. That could show good and not be good enough for amperage flow though.
/ BX22 wont start #8
From the symptoms in your original post, I would suspect the the original battery is low on charge, and that the jumper cables are not allowing enough current pass from the jump battery to start the motor.
Connect your voltmeter across the tractor battery, and attempt to start. If the voltmeter indication drops below 9.6 volts cranking, fully charge the battery. It is also important to remove the wires at the battery posts and inspect. The mating surfaces need to be clean and shiny. If they are gray, wire brush or lightly sand until the mating surfaces are shiny bright.
Most battery jumper cables are marginal at best. Pull back the sleeve that covers the wire junction to the cable clamps. If the wire is merely crimped, I would suggest soldering these connections. This simple step will improve the electrical connection between the cable and clamp. Also, if the wire in the cable only has a few individual strands, it will not be of much help when jumping from one battery to another.
To get the jump battery to put voltage into a battery that is low, the charging battery needs to be about two volts greater than the battery that is low. This means the two battery s are connected together, then the jumping vehicle engine needs to run at a fast idle to move current to the low battery. Allow five minutes running time at fast idle before trying to start the tractor. If the tractor starts, the battery voltage should climb to a value of at least 13 volts. This indicates that the charging system is working.
Let us know what you find.
/ BX22 wont start
OK she started right up today. Went out and checked battery w/ the POS still disconnected , meter read 12.5v. Cleaned terminals and stuck it on loose. Turned key...good fuel pump buzz.....Vroom. Did little dance of joy. Put side bonnet back on tightened everything up ( battery first) and ran for 1.5 hours. No problems.
I think there could be some moisture/corrosion that froze up in some connection , enough to stop the engine from turning over at first. But that doesn't explain the engine not starting when hooked up to the stater with the jumper cables.
One possibility for this is it was fuel related even though I had flow, when cranking the key, out of the 2nd filter output. It's 40 deg out today and I didn't go out to work on it til 3PM. So it sat several hours ABOVE freezing.
I had just filled it before my last use so maybe there was some water in the fuel. Perhaps it settled in the engine lines ? I use ON road diesel from the local BP station. It's close by and the fuel is usually fresh as a lot of trucks fill up at the pumps. I use maybe 25-50 gallons a year so no big hit on the extra taxes. I always assumed the fuel had Antigel in it being ON road fuel. Maybe I'm wrong......think I'll pick up a bottle on CENTANE Boost/Anti Gel or whatever it's called and start adding it again.
One good thing I saw was the starter gear is outside of the engine and pushes out to engage the flywheel to crank. I was thinking I needed to tear it off and see if there was damage to the gear or the gear pin had sheared and it was slipping on it's shaft. No need to with this set up.
SO not sure but think I have a few issues to work on. I'll try it again next time it gets cold and see if the problems return.
/ BX22 wont start
Almost forgot , Thanks for the input. You guys are always a wealth of knowledge.
/ BX22 wont start #11
Battery fluid can freeze if there isn't enough of a charge. It is possible that your battery had some ice in it. The amps required to start a motor, especially a diesel, are high enough that jumper cables have a real hard time passing that current along. I would recommend that you pull the battery to some place that stays above freezing for a couple days, then put a low amp charge on it for a day or two. If your battery is partially froze and you put a charge to it, there is the possibility of it 'boiling' over. If you have a warm garage, that is the best place because of the fumes that your battery can put off. Oh, and keep it away from sparks or open flame. =) In all, it just sounds like you weren't getting the amps you needed to really spin that motor.
/ BX22 wont start #13
My bet is that all of the fooling around with the connections allowed for a better hookup and full current was flowing.
I had a L3650 that had "battery" problems similar to the OP. It turned out that the battery was grounded to the frame instead of the engine. Eventually, the connection degraded until only a trickle of current went through. Everything lit up but the engine wouldn't crank. Oh, and the tach would jump all over the place intermittently.
It was diagnosed by hooking a jumper cable from the battery post to the engine. The tractor started right up. A trip to an auto parts store for a longer ground cable to attach to an engine bolt cleared up all of the electrical problems.
/ BX22 wont start #14
Hmmm original no start day temp in low 20's. Started couple days later I bet the temp was warmer. Sounds like cold thick oil to me.
/ BX22 wont start
Maybe on to something because the fuel gage and temp gage where acting funny the usage before the no start day. They where both pegged into the negative zone. Not just at zero but pegged to the lower limit. Now of couse they are working fine. HMMMMM
/ BX22 wont start #16
Is this your original battery? If it is, I'll bet on a bad battery-------it's old. The best advice was to take it to an auto parts store and have it tested. A weak or bad battery can cause all kinds of weird problems. If it's fairly new, I might have it tested anyway-----they don't make em' like they used to, and a tractor bouncing around can be hard on a battery. If the battery tests OK, then as others have said, check all + and - connections from the battery. Make sure they are clean and tight!
A fuel problem won't cause your symptoms. And even if you are using 15w-40 oil, it hasn't been cold enough around W. PA to thicken the oil that much. We would need to lose another 25 or 30 night time degrees to worry about that.
A few months ago I had intermittant starter problems on my old JD 210 garden tractor. If I gave the starter a rap with a stick, it would start up. Turns out it wasn't the starter after all but a loose + wire to battery clamp. I tightened that up and no more starting problems. I'm guessing that my moving stuff around while using the stick method gave enough of a connection to start the tractor. I keep all electrical connections that I can covered with di-electric (SP) grease to help prevent corrosion too.
/ BX22 wont start #17
I still think you have the problem. I don't know what a good, fully charged battery should read, but I think it should be more than 12.5v.
/ BX22 wont start #18
I'm kind of in the same boat. My BX wouldn't start. (Turned over slowly) Pulled the battery out and cleaned connections and charged the battery. I didn't check the voltage before I charged it, but after it was 13.5 Volts. I was led to believe a fully charged battery was 12.7 V? Anyway it starts good now. The battery is the original Deka 10 years old. If it happens again I will be looking deeper. Probably time for a new battery at any rate.
Kim
/ BX22 wont start #19
12.7 volts is a good reading, depending on a couple of factors. Just after being charged, the battery voltage will read closer to 13.5 volts. After resting for a few hours this voltage will drop to more like 12.5-12.7 volts at room temperature. On a cold day that could be a few tenths of a volt lower.
Ten years is a pretty good lifetime for a battery. A replacement may be in your future.
/ BX22 wont start #20
Kim
10 years?? Wow!! Good life, but, time for a new one so you don't have to chase a problem caused by a "faithful" battery!
2010 Ford F-350 Crew Cab Diesel (A62679)
2010 Ford F-350...
LUND DIAMOND PLATE TRUCK BED TOOLBOX (A64280)
LUND DIAMOND PLATE...
UNUSED KIVEL 48" PALLET FORKS (A64280)
UNUSED KIVEL 48"...
UNUSED ATS POWER ATS-PC90 HEAVY DUTY PLATE COMPACT (A64281)
UNUSED ATS POWER...
2022 Ram ProMaster 2500 Cargo Van (A61573)
2022 Ram ProMaster...
2019 PETERBILT 579 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2019 PETERBILT 579...
