L3200 This decal can't be right
   / L3200 This decal can't be right #1
Slimson
Member
Western Washington
Kubota L3200, 1949 & 1953 Farmall Cubs
This decal was just as shown in the picture when my new tractor was delivered. I'm sure that brush guard can handle my weight.
I haven't been able to determine where it really belongs.
My WSM doesn't show decals for the loader, so I assume it belongs somewhere on my loader. Anybody know where it goes?
   / L3200 This decal can't be right #2
Eh, it belongs in the trash. Pointless limiting of liability, IMO. If there's any part of your loader frame or brush gaurd that can't support 250 lbs, it doesn't belong on the tractor.
   / L3200 This decal can't be right #3
Looks like it came loose from somewhere else, the way its hanging half-way on. My guess is that flat steel cover on the cross bar of the loader that protects the hydraulic lines. Its close to the loose label, looks like a perfect step for climbing on, and is probably thin steel.
   / L3200 This decal can't be right #4
Yup, pretty sure my LA504 has that sticker over that sheet metal guard.
That would make sense- I got rid of it anyway. I was just curious, Thanks.
   / L3200 This decal can't be right #6
+3 on the little flat sheet metal cover over the hydraulic lines on the torque tube. it just blew off and stuck on the guard is all.
James K0UA
   / L3200 This decal can't be right #7
Looks like that piece of metal on the guard is on an angle and they don't want you stepping on it for safety so you don't slip off and get hurt.
   / L3200 This decal can't be right #8
James K0UA
+4:thumbsup: That is where it is on my L3400/LA463. It is just a thin peice of metal and they dont want you smashing it down into the hydraulic lines. Not that you would smash the lines even if you weighed 500lbs:confused2: But they dont want the guard to be in constant contact cause the vibrations would eventually wear through the steel lines.
:laughing::laughing:
Pretty sad adhesive on that sticker though. Heck...I've power wasked my tractor several times over the 6 years I've had it and my stickers are all still intact.
   / L3200 This decal can't be right #10
NO STEP >>>
2016 FREIGHTLINER CASCADIA (A50854)
2016 FREIGHTLINER...
2006 INTERNATIONAL 4300 DT466 SBA 4X2 BUCKET TRUCK (A51406)
2006 INTERNATIONAL...
STS MUD MIXING MACHINE (A50854)
STS MUD MIXING...
SET OF HANG ON WHEEL LOADER FORKS (A51242)
SET OF HANG ON...
Bron V75-3 Pull-Behind Hydraulic Vibratory Utility Plow (A49461)
Bron V75-3...
2006 MACK GRANITE CV713 DUMP TRUCK (A51406)
2006 MACK GRANITE...
