Herkypilot
- Joined
- Oct 3, 2011
- Messages
- 566
- Location
- Meadows of Dan, VA
- Tractor
- Kubota M7060 HDC12, KX040 & L3540 HST
As most know, the MX4700/5100 doesn't come with a rubberized floor mat so I decided to add one before all the paint was worn off the steel deck. This is a 3'x4' stall mat which can be purchased from TSC for about $20. It took me a couple of hours to cut this down with a razor knife. I used some cardboard to create a template for the curvature around the wheel wells. Other than that, it involved a lot of trial fitting and trimming. It is held in place with 1/4" x 1 1/2" grade 2 nuts, bolts, washers & lock washers. With the thickness of this mat, I would expect it will last about 10 times as long as a factory mat.
HP
HP
