MF Model 25 Disk
/ MF Model 25 Disk #1
Edelpils
Leroy, Texas
Ford 515
First post on the forum and pretty much new to tractors and plows. I just went out and bought a MF Model 25 disk Plow to hook up to my Ford 515 Industrial Tractor. Bought the 515 back in OCT. It's not pretty but it works. I plan on rebuilding the plow this year, but i have to disk about 4 acres with it as soon as the ground dries out. It's been raining here in Texas for the past couple of days. The Model 25 has no cracks in the frame and there is only two things i see wrong with it. The first being that someone welded the places where the scrapers bolt on to and also the housing around a bearing is broken. I think i'll fill up the housings with grease and Pray that it holds for the 4 acres for now. Then during the summer i'll get a new housing for it and tear it apart and paint the plow. I just ordered a manual for it yesterday, so i'll know the proper names of everything. Anybody know where to get parts for these old Model 25 Disks? I will update you on how the rebuild goes. Here are some pictures of the model 25. From what I understand by reading on line the MF I have is the biggest one they made for the model 25. It has 7 disk on each axle for a total of 28 disks. Cant wait until it dries enough to get out and PLOW..... Winter Sucks. P.S: Any tips or hints or info on the model 25 would be appreciated.
/ MF Model 25 Disk #2
Agri Supply has a lot of parts that you can fit onto that 25.
Agri Supply - Search=
What's the engine hp on your 515? It ranged from 40-99 hp on that series.
/ MF Model 25 Disk #3
Congrats on the find....and welcome to TBN. I believe this is the model that FWJ (Farms With Junk) speaks so highly about. They are supposed to be the Cadillac of discs from what I have read. You may want to listen to his take on your disc.
OH.....and you could use the search function to read more on this disc. Try a key word of "MF 25 Disc" or something similar.
/ MF Model 25 Disk
Flusher:
I have been told that the engine has 59HP. I have been unable to find out completely though. I bought the owners manual and service manuals for it, but it's a general manual that covers from 230A to 545A. When i looked in the service manual it did not list my tractors HP. It listed a 230A, 340A, 445, 540A, 545. So i have to do more research. what i did notice in the manual is 230A had 33hp and when it gets up to 545 it has 55HP. So to make a logical guess i would have to say low to mid 50's. The Model # is DU212K. I know everything except the DU2. D is suppose to stand for HP and U is for the Chassis Type. The first 2 stands for design stage going by the manual. What ever that means. Anyone know?
/ MF Model 25 Disk #5
I was "gifted" the same disc harrow by my wife's Uncle to use with my '47 Ford 8N. I think it's the same one - I cleaned the paint/grime off the ID tag last summer but it is under the snow 2.5 hrs. away at our summer cottage. I had to do a bit of welding & replaced a couple of broken discs. Mine does not have the scalloped discs on the front gang, they are smooth same as the rear gang. Used it a few times in the Spring on our gardens. It is a load on the 3 point for the old Ford. From what I could find on the Internet at the time, mine may use hardwood bearings for the discs?
/ MF Model 25 Disk #6
That is quite a load for an 8N. You must have to steer it with the brakes.:D
/ MF Model 25 Disk #7
Only have to steer with the brakes when pulling hard in soft wet ground (when I shouldn't be in there anyway). It doesn't take much of a bump in the lane when transporting with the hitch raised up for the front end to get VERY light. This particular disc harrow was purchased new as a package with a Massey Ferguson tractor similar to an 8N. I have seen an old photo but can't tell if it's a TE-20 or TE-30 - it was definitely not a 35 or larger.
/ MF Model 25 Disk #8
I have the same harrow. It is a sturdy piece of equipment and should handle your four acres without a problem. Your harrow is missing all the disc scrapers, but if you don't have clay soils it might not matter too much. As someone else noted, the bearings are made out of wood, so make sure they are well greased at all times. You might want to take them apart and check their condition. If you need a manual let me know and I can send you a copy.
/ MF Model 25 Disk #11
Never saw a #25 MF disc with wooden bearings. They're cast iron on ALL of 'em I've ever worked on. My parts manual only has listing for cast iron......
/ MF Model 25 Disk #12
I also have that model disk in a 6 footer. Does a great job..!!! Love the semi-float of the gangs. That baby will really cut..!!
There used to be one setting at a small dealer on Rt. 68, between Maysville, and Paris KY. Appeared to be a 7' model. Always wanted to stop, and see what they wanted for it, for my buddy. But too far to go for us, just for that.
/ MF Model 25 Disk #13
Must of found some scrapers somewhere there in the video.:)
Keep us posted on the rebuild as I've got the same job looking me in the face. Details please.
/ MF Model 25 Disk #14
Hi Guys, looking for a bit of help. I broke a couple disc blades on my model 25 disc. I removed the axles from the disc frame and cannot for the life on be get the spacers/spools free. They are seized to the shaft. I try tapping it, WD-40 and even a press. Any pointers would be much appreciated. I don't want to ruin the spool for the bearing box because they aren't available any more. Has anyone had this issue before? Also, is there anyone around that has parts? I just want a few spacers and maybe the spool spacer. Thanks!
2013 HAULMARK ENCLOSED UTILITY TRAILER (A67714)
2013 HAULMARK...
2011 SPM SAFETY IRON 100 BBL 10 PUMP MANIFOLD TRAILER (A67714)
2011 SPM SAFETY...
1999 Freightliner FL112 Tri-Axle Dump Truck (A66736)
1999 Freightliner...
Unused 2024 Land Pride RCF2072 6ft. Rotary Brush Cutter Tractor Attachment (A66734)
Unused 2024 Land...
HYDRAULIC FLUID TANK (A68842)
HYDRAULIC FLUID...
2013 CHEVROLET 2500 HD (INOPERABLE) (A67714)
2013 CHEVROLET...
