3720 owners second scv not always working
/ 3720 owners second scv not always working #1
DP Property
BelleRiver, Ontario
Kubota B7510, JD GT235, JD 757, JD Gator 850D, JD 3720 hi-spec cab on order
I have the optional rear scv installed in my 2011 3720. There is a three way switch on the right control panel to select the functions. I push it forward and the rear valves open and control the snow plow angle left and right. The last snow storm the angle left and right failed and stopped working but then after turning the tractor on and off and playing with the switch would resume.
Today well moving the tractor in warmer weather the same thing happened when I engaged the switch the left and right angle would not work. I turned the tractor off and opened and closed the rear valves manually with the little adjuster at the rear. It worked again but when I played with the switch then reingaged it , again nothing.
Stupid question but what should I be looking for in order to trouble shoot. Fluids are all good and loader functions work fine. I am reading the manual and I don't understand how the selective control valve lock lever works. I see it in the manual saying it does all sorts of things but in the actual tractor all I see is a little lever that pulls out and pushes in and says joystick lock lever.. a little confused but can't have the scv failing to function in the next snow storm we get. Anyone else had problems? could it be a bad selector switch or the valve control unit at the rear of the tractor or is it the operator?
/ 3720 owners second scv not always working #2
My 2nd function switch sucks, asked the dealer to change it at the 50 hour service. They apparently forgot. I often have to sometimes switch it off and back on to get the red light to illuminate. But in your case it sounds more like the solenoid valve itself. If it's the 2011 listed in your signature line, the solenoid is the rearmost of the two that are located beneath and forward of the right cab door. A 2011 must be still under warranty though. I'd let the dealer remedy the issue.
//greg//
/ 3720 owners second scv not always working #3
your scv lock lever has nothing to do with the rear scv just so you know. It can lock the joystick in neutral, or engage and disengage the Regen feature for bucket dumping. that is another story for another day.
I just got my 2012 3720 cab and i also hate the rear scv. the buttons on the joystick seem to stick.
I wired in a toggle switch to control the 3rd rear scv also. It is a switch from a 4720 cab that would control the 4th or 5th rear scv. I just tied it into the joystick switch so i can use either one. So far i like the toggle way better.
I also made a 4th scv for the rear by adding an open center valve. i'll get pics of that up soon. I am controlling it with the scv lever and cable from an early model 3x20 cab. The lever goes in the slot to the left of the 3pt lever. It looks 100% factory and so far works great. best part about a manual scv is a got the float function again.
//greg//
Ok Thanks Greg was just playing with it again this morning and doing some maintenance checks and now it is working. I don't understand the joystick lever lock it says it has 3 positions in the manual yet it feels like you can push it in once or pull it out. My loader control does not lock in place? I see no difference in how the scv works? do you have any experience with this lever and what exactly is it supposed to do?
Also there is a little plug sticking out the back window just wondering if you knew what it might be for? still learning about this tractor.
Thanks
David
/ 3720 owners second scv not always working #5
Well, I'd need a photo to be sure, but I think it may have been put between the glass and the seal by accident. I've got the standard seat, and have a spare wire and connector lying on the cab floor. I assumed it was for the air suspension seat upgrade. But I do have a pair of open connectors (purple) outside the cab. They're just dangling to the left of the QD bracket. Again, I've got nothing to back this up. But I assumed they were there for the electric rear solenoid option.
As far as the little lever beneath the joystick, I too have found both it and the manual to be useless. Not only does it not seem to respond to the actions described in the manual, it doesn't seem to do anything at all !!
//greg//
//greg//
Ok Thanks again Greg I did put up some pictures but maybe you can't see them. I do have the air ride seat installed I will send the pictures to the dealer and see if he can identify what the plug is for.
/ 3720 owners second scv not always working #7
yeah, I see them now. Apparently they hadn't finished loading when I first glanced (slow connection). But that looks larger than the connector lying on my cab floor, methinks' it's something else. I see some other device to the right of it that I don't have either. So I'm thinkin' our rear hydraulics may not be configured the same after all.
//greg//
How do you lock the joystick it does not seem to lock it at all when I pull it out or push it in? does the tractor have to be off to do this? does it lock the loader in float position or something? regen feature I read about that in the manual but that little lever does not move like the manual says it does?
/ 3720 owners second scv not always working #9
I can't remember off hand but i think you push the lever in to lock the joystick. I was messing with mine and it finally went after wiggling the joystick around. It was not an easy task.
and i think the regen is in the middle position????
When in regen you can move the joystick farther to the right. You can feel it go into the next "slot" compared to if the regen is off. It takes a little messing with to figure it out.
I noticed when i had the RH console on mine off the lever moved alot easier into the 3 designated "detents". Maybe the console is binding with the lever somehow? I didn't take the time to investigate because ill never mess with mine again anyways.
Probably smart never mess with pretend it's not there..lol . Thanks I will check it out one more time then be done with it :confused2:
ok talked to the dealer there was a bad batch of solenoids that would stick. I just got in from another small snow storm and my helper was running the tractor and after an hour of use it stopped working again and we could not get the blade to angle for the rest of the storm. (it was stuck)
I will call the dealer in the morning and request a new part can't have that happening all the time.
/ 3720 owners second scv not always working #12
I think that plug is for the optional backup alarm. You have to move the joystick around a little while pushing in on the lock. Locks real easy when my knee rubs against it usually when I don't want it locked! There is three positions to the lock. I will stick with the good old mechanical third SCV because it works and it DOES have float! The joystick mounted electric control would be handy but it has to be a quality/dependable setup for sure!
/ 3720 owners second scv not always working #13
Did you ever post pics/details of the 4th scv? Maybe I just missing them, but have been interested since you posted that it's possible.
/ 3720 owners second scv not always working #14
hopefully this weekend i'll get around to it.
Just an update before this winter had my local JD dealer take the machine and trouble shoot they found a bad ground on the wiring harness hidden under all the side paneling I would never have found it. This fixed the problem finally and the SCV worked perfect all winter long :)
