flusher
Super Member
- Joined
- Jun 4, 2005
- Messages
- 7,572
- Location
- Sacramento
- Tractor
- Getting old. Sold the ranch. Sold the tractors. Moved back to the city.
thanks guys.
i picked up 6011 rod sat. night they did not have 6010 but when i started to weld with it { again } the rod kept sticking several times i noticed when i could not release the stinger ? fast enough the flux burned off the rod { went up in smoke } what`s with that & then i had to pitch the rod.
candyman
Fresh 6011 rod--start by scratching it quickly on the side of your welding table a few times to burn the glob of flux off the end of the rod (don't mess up the surface of your table by doing this there). Turn up the amps in 5 amp steps until the sticking stops. Use DC positive. Concentrate on holding the arc gap to about 0.1". Angle the rod about 30 deg from vertical.
