Welding lead quage
/ Welding lead quage #1
westbrooklawn
North Carolina
kubota L3400HST
I have two stick welders... a Miller Thunderbolt AC/DC and a Miller Maxstar 150 that I bought used from a welding pro. I find myself using the Maxstar more and more, simply because of it's size and ease of setup. The original owner had put a 35' #2 wire on the electrode lead, and a 12' #4 wire on the ground lead... it welds just fine with this setup.
Now I want to extend the ground lead to 35', and I already have 35' of spare #4 wire. This would end up with a total lead length of 70', with one lead being #2 and one being #4. I hardly ever weld over 125 amps, and with short duty cycles. Some charts indicate you can go 100' at 150 amps with #4. Other charts show that 100' at 150 amps requires #2 wire. I can't find a chart that shows what I need for 70', but I feel the combination of 35' of #2 and 35' of #4 should be fine up to 150 amps. I see no reason why the difference in lead size would matter as long as the smallest ga. wire can handle the load. What do you welding experts think?
/ Welding lead quage #2
I looked at a couple of charts. and the ones I saw said good for up to 150 amps at 100 foot. so you are 70 foot, and you have a combination of larger stinger lead so slightly less drop. And you will be welding at 125 amps not 150.. I say go for it.
James K0UA
Oh, I am not a welding expert, nor play one on TV and I did not stay at a Holiday Inn last night either.
/ Welding lead quage #3
It was brought to my attention that the lengths on those charts are the combined lengths of both cables.
Ian
2017 Ford Explorer AWD SUV (A66738)
2017 Ford Explorer...
2008 FORD F150 EXTENDED CAB PICKUP TRUCK (A66091)
2008 FORD F150...
2017 Hyundai Santa Fe AWD SUV (A61574)
2017 Hyundai Santa...
CATERPILLAR CS44B SMOOTH DRUM ROLLER (A64279)
CATERPILLAR CS44B...
Skidded Fuel Cell (A67714)
Skidded Fuel Cell...
CATERPILLAR D9T CRAWLER DOZER (A64279)
CATERPILLAR D9T...
