PTO Leaf Blowers?
/ PTO Leaf Blowers? #81
Our successful track record has indicated that Consumers are intelligent and that they will make good decisions if giving the facts, however if not all of the facts are accurate, they may make a decision they might regret down the road. I would rather explain our position up front than to defend a Poor product for a lifetime.
I am confused how releasing your CMF amd MPH specs would result in you having to defend a poor product for a lifetime... Not quite sure what the connection is there.
Please also note there are only 3 Turbine style Blower manufacturers on the market. Buffalo Turbine is the only one that offers a Turbine Style blower that is not a Pull Behind.
Actually, it appears that Toro and Agrimetal both make a skid mount turbine blower... They however do not have a 3 point turbine blower.
http://eckertgolf.com/KB3_Manual (Updated).pdf
Looks like section 7, page 19 of the manual has the super secret product specs.
We no longer have to be mushrooms - let the light shine
Good find. Looks like that might be the previous generation of blowers though as it is belt driven rather than gear/direct drive.
Aaron Z
/ PTO Leaf Blowers? #82
Thank you for your reply. As you may have noticed with your research, neither Toro or Agrimetal list specifications for their turbine style blowers.
I would like to encourage you to contact Buffalo Turbine so we may have a discussion regarding your concerns.
If you would like to purchase a PTO blower you have the right to choose which blower may be right for you and base your decision on specifications provided by manufacturers no matter how accurate they may be. If we have a dealer near you and you would like to see the product in action then please let us know and we will help arrange that. If you would like to rent the product for your own uses by the week or the month we will be happy to arrange that as well.
If anyone in this forum would like more information about our products please contact us. We are here to assist you and answer your questions about how our products may save you time and labor for your applications.
We will remain proactive in assiting you with solutions and we are an American Made Manufacturer and we are based in Western NY since 1945.
/ PTO Leaf Blowers? #83
/ PTO Leaf Blowers? #84
I'm just guessing, but it seams reasonable to assume the Buffalo Turbine will not put out the same numbers as may be found published by squirrel cage blower manufacturers, since they probably publish best case airflow numbers and the Buffalo Turbine unit obviously blows through an elbow all the time.
It's not unreasonable that they would rather discuss maintained performance in all directions than compete on published maximum numbers. I don't see this - by itself - as any kind of negative. It does seem reasonable that they hope to win buyers through demonstrations of effectiveness rather than number publishing. It's a strategy that might lose some sales, but win others.
I have seen one of their units in operation at a road coarse track South of Houston, and it did appear quite reasonably effective. The maintenance staff use it for cleaning the track surface of debris, inclusive of gravel that winds up on the track after a car hits the gravel pit.
/ PTO Leaf Blowers? #85
You are right - that was an old unit. Here is the manual for the new unit.....and we are back to being mushrooms...
http://www.doriandrake.com/download...eets/Cyclone PTO Manual Color Rev.7.30.09.pdf
No CFM info in there... But the inset on page 23 was an interesting read, especially the part that says "Part # 1256 (center section) is a WEAR item that should be visually checked each time the engine oil is changed" odd thing to see on a PTO blower...
Aaron Z
/ PTO Leaf Blowers? #86
I know it's 8 years late, but in case someone wanted to know, I found the specs:
Source
Model HURRICANE/PTO Model KB2 Series
Air Flow: 10,000 CFM 10,000 CFM
Outlet Size: 12” 12”
Outlet Velocity: 175+MPH 175 MPH
Case 1845C Skidloader (A66285)
Case 1845C...
Lonestar Panel (4) 24ft. Free Standing Panels (A65640)
Lonestar Panel (4)...
Skid Steer Bale Spear (A65640)
Skid Steer Bale...
(2) TOOL BOXES (A62613)
(2) TOOL BOXES...
2018 Chevy Traverse 3rd Row Seating (A63689)
2018 Chevy...
20ft Driveway Gates (A65579)
20ft Driveway...
