picture worth a thousand words
   / picture worth a thousand words
clicked the button to soon, here it is.....
   / picture worth a thousand words #63
That'll give you some serious welding/cutting power. A real 8500w is close to 40amps 220v and should run about everything a non industrial shop would run.
thanks guys.
i picked up 6011 rod sat. night they did not have 6010 but when i started to weld with it { again } the rod kept sticking several times i noticed when i could not release the stinger ? fast enough the flux burned off the rod { went up in smoke } what`s with that & then i had to pitch the rod.
candyman
   / picture worth a thousand words #65
I'm not an authority, but maybe you need to turn up more amps.
Nice generator.
   / picture worth a thousand words #66
thanks guys.
candyman
Normal to flake/burn off the flux when they stick hard.. tell us what current setting you are using, and what size of rod you have and what technique you are using to strike the arc..Everyone sticks a rod now and then, begineers stick more than just now and then, but if you are set too cold, then they can stick more, and vertical pecking (though some disagree) seems to stick more for me, I like to "scratch" at an angle. It takes some practice, and some rods stick more than others. Stay with it, and we will stay with you to help.. I don't suppose you live any where near Branson, MO.?
James K0UA
   / picture worth a thousand words #67
One tip for 6011 with those inverters. I find on my longevity 6011 will only run on the 6010 port. The 6011 is an AC/DC version on 6010, and it seems the difficulty of running on inverters is the same.
thanks, well i`m not sure about the amps 90 maybe rod is 3/32 hobart. i am using the i`m paying no attention technique i get so pi#@$% when the rod sticks i loose my focus.
candyman
   / picture worth a thousand words #69
candyman
You will have to learn to accept that you're going to stick the rods when you learn. Experienced guys still stick rods. Part of the PITA of learning stick welding and part of the reason that MIG is so popular with new weldders. Still, stick is a very valuable skill so it makes sense just to keep going until you get it right. You shouldn't need to waste a whole rod though if you stick it. Just cut off the bad part, clean a bit of flux off the very tip and keep going.
2003 International 4300 S/A Day Cab Truck Tractor (A55852)
2003 International...
2012 Volkswagen Tiguan AWD SUV (A55853)
2012 Volkswagen...
2024 New Holland Skid Steer (A52377)
2024 New Holland...
UNUSED FUTURE CAT305 EXCAVATOR AUGER DRILL (A57193)
UNUSED FUTURE...
(APPROX 32) 6' X 12' HEAVY CHAIN LINK SITE PANELS (A54757)
(APPROX 32) 6' X...
2021 Liebherr L556 (A53472)
2021 Liebherr L556...
