adding rear remotes on L4330
/ adding rear remotes on L4330 #1
nctacoma
Member
Vermont
Kubota L4330
Hello,
I would like to add a set of rear remotes onto my L4330. Is this something I can walk into the Kubota dealership and order as a factory/stock item?
Thanks
/ adding rear remotes on L4330 #2
Kubota makes kits for alot of there tractors, but they can be pricey, BUT they are fairly easy to install if you have good mechanical skills . Kit should have good instructions. I did my freinds L3830 GST 4 months ago , took about 2 1/2 hours, taking my time. Did my B7800 5 years ago, took a little longer. Your L4330 should be fairly easy. But look to pay $850 to $1350 for kit alone . Shop around so online dealers may charge $50 to $100 less. Good luck. Steven.:thumbsup:
/ adding rear remotes on L4330 #3
Hello,
Thanks
Dealer installed remotes are very expensive, probably >$1K for dual remotes.
I was fortunate that my Mahindra dealer offered triple remotes for $700 (for my 2008 Mahindra 5525). Can't pass up a deal like that.
If you want to DIY and save some $$$, check the Hydraulic forum on TBN. There's a lot of good info on how to do it. You can get all the parts you need from Surplus Center (which advertises here on TBN).
Surplus Center - Hydraulics, Engines, Electrical and More
Good luck.
/ adding rear remotes on L4330 #4
I ordered a Kubota remote kit from Barlow in KY. I tried to spend money with the local dealer, but after 2 weeks it still wasn't ordered so I went this route. It was over $100 less and I had it in 3 days.
Unused 10-16.5NHS Skid Steer Wheels and Tires (A61572)
Unused 10-16.5NHS...
Raven CR7 Monitor (A63117)
Raven CR7 Monitor...
2R PLANTER, 3PT (A64280)
2R PLANTER, 3PT...
2016 Crane Carrier Co. New Way 31ASL 31Yd Side Loader Garbage Truck (A61573)
2016 Crane Carrier...
Rhino 7ft Blade (A63688)
Rhino 7ft Blade...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
