Curl Bucket Cylinder over extended on VTEK?
   / Curl Bucket Cylinder over extended on VTEK? #21
I think I am going to order from VN1(little more $$) to assure I get the correct cylinder but I thought I would post up the measurements I took off the one good one I have for posterity:
Stroke: 11 1/2"
Cylinder Diameter (not Bore): 1 15/16"
Rod Diameter: 1"
Retracted - Center of eye to center of eye: 20 1/8"
Extended - Center of eye to center of eye: 31 3/4"
Eye hole: 3/4"
Looks like Surplus center has a match with a 12" stroke. Part number 9-7270-12.
i like to see the rod diameters 1 1/8 and and eye hole 1" for a good loader.what did all this set you back$???
the new cylinder was $160. I could have gotten it cheaper but it would have been slightly off from the other stock one. The coldwater loaders have a single cylinder for the tilt right?
Someday I would like to beef it up with larger cylinders
   / Curl Bucket Cylinder over extended on VTEK? #23
160 not bad.i seen loader cylinders go for a a lot more.
2016 Takeuchi TL8 (A47384)
2016 Takeuchi TL8...
2024 Ford F-350 Super Duty XLT FX4 - Like-New, Loaded, Only 780 Miles (A52128)
2024 Ford F-350...
2021 New Holland P2350 Air Cart  New, Tow-Between, Intellirate Control, Dual Tires (A51039)
2021 New Holland...
John Deere 637 Disk (A50514)
John Deere 637...
2011 Ford Explorer Limited AWD SUV (A50324)
2011 Ford Explorer...
Case IH 2608 8 Row Corn Head (A52349)
Case IH 2608 8 Row...
