Car axle used on a trailer?
   / Car axle used on a trailer? #1
bnew17
Georgia
2001 JD 5310 w/ 542 FEL
Ive got a small utility trailer im wanting to beef up to put a bbq smoker on. Im looking for a 3500 pound axle but having trouble locating a used on. I did have a fellow offer me a plymouth minivan axle with tires for 60 bucks. Would this work? what would this axle be rated for?
   / Car axle used on a trailer? #2
Well it would seem to be rated for half the weight of a fully loaded mini at least.
   / Car axle used on a trailer? #4
If its a 5 lug I would think the rating would be close to/ in the 3500 lb range. Find out the year of the van it came out of and look up curb weight and towing capacity, that should give you an idea
Case. I believe it is a 5 lug. Is $60 a fair price on it?
   / Car axle used on a trailer? #6
If its complete with bearing,hubs,drums I would think it is. If I remember right the last 3500 lb bare trailer axle I bought was around 100.00 plus bearing hubs etc
   / Car axle used on a trailer? #7
The curb weight is 3670. Some were rated at 7 passengers. Really need to look at the door sticker on vehicle.
I wish I could but I believe the guy bought it from the owner of the van so there is no way to know for sure unless the new owner remembers the year and model of the van. I do remember he said it was a plymouth van
Would it be rated for half that?
   / Car axle used on a trailer? #10
If you figure 150 pounds per person (conservative), that's another 1050 pounds. Figure another 150 pounds for fuel and a couple hundred for luggage, etc. and you're over 5K for the entire vehicle. 2500 lbs sounds like a very safe estimate for the capacity of this axle. I'd figure it as a 3K pound axle if I were doing the build.
   / Car axle used on a trailer? #11
I think I would stay away from automobile axles. Spring perches, brakes, etc will all be headaches.
Trailer axles are relatively inexpensive new and usually can be found very cheap on craigslist. In my area you can find a complete axle with springs and electric brakes for $150-200, usually with tires.
   / Car axle used on a trailer? #12
+1 I've seen bare axles at TSC - surprisingly cheap.
   / Car axle used on a trailer? #13
If this smoker is gonna need a 3000lb axle, then you are definitely going to need trailer brakes...
Magic Wagon/Caravan axles are great for light duty stuff, where you don't need a lot of ground clearance, but I'd keep the loads under a ton, because of the lack of brakes.
   / Car axle used on a trailer? #14
One benefit to a minivan axle is you could use a surge brake actuator with the existing brakes if you want surge brakes, or you could use the brake cables from the ebrake and make parking brakes.
Aaron Z
   / Car axle used on a trailer? #15
I would just build it because unless you plan to have 4 sides of beef and a couple pigs on the BBQ at the same time you will have way more axle than load and it would no longer be a small utility trailer .
Im guessing the ballpark weight of this smoker to be around 1000 pounds.
Since i already have this trailer i mise well use it. I dont have the money to go out and buy another trailer, plus i figure i can beef it up to what it needs to be for much less than building an entire trailer.
   / Car axle used on a trailer? #19
I agree with you. This sounds like a dedicated trailer that you're not going to be overloading with metal scraps or something crazy like that. You have the trailer, you have the axle, and it sounds like you have the skills needed to modify it.
Do the modification and enjoy taking your smoker wherever you want.
SKID STEER ATTACHMENT PICKER (A58214)
SKID STEER...
John Deere 7410 (A53317)
John Deere 7410...
HUSQVARNA RIDING MOWER 46IN DECK (A56859)
HUSQVARNA RIDING...
ExMark Vantage 48in Stand-On Commercial Mower (A59228)
ExMark Vantage...
2017 Toyota Hybrid Camry Sedan (A59231)
2017 Toyota Hybrid...
2008 TEXAS BRAGG GOOSENECK FLATBED (A58214)
2008 TEXAS BRAGG...
