3005 tool box done today.
/ 3005 tool box done today. #1
Jamming
Gold Member
Northern Washington
John Deere 3033R
Hit the shop this morning early, finished my tool box and chain setup.
$14 in two cans of paint, with left overs.
$20 in steel
$20 for the u bolt kit, just bought another canopy top mount kit. 2x3 rop.
$60 for the limited tool box, nice steel by the way, its heavyier than my craftsman that looks the same.
6 hours of work, getting the angle right for the ROP was a little tricky if you decide to do this because its also off camber and of course angled. I made a cross member out of wood first then used it for the steel referance.
Hope you like the chain idea, bad comments also welcome. ;)
/ 3005 tool box done today. #2
Nice work you do there. Looks handy, and if it isn't then you can just add or subtract as needed. :)
/ 3005 tool box done today. #3
Looks nice. What holds the toolbox in the support frame?
Just the back and front corners, If i roll over i might get a head full of tools. But its in there snug, I wanted to be able to remove the box.
/ 3005 tool box done today. #5
Cant it bounce off if you hit a bump??
/ 3005 tool box done today. #6
Looks like a factory install. You should sent it to John Deere and ask for Royalties when they put it on all tractors.
/ 3005 tool box done today. #7
One of those $0.99 rubber cargo straps ought to hold it in there tight even when bouncing or even upside down.
/ 3005 tool box done today. #8
Well Done! I like the chain carrier idea too. :thumbsup:
I made a similar set-up for my 790 when I owned it.....and it sure was handy. I realize how tricky it is to get the proper relationships of the "bracketrey" due to all the compound angles - nice job.
I wish for one on my current tractor....but get along with the fender box. I do wish some enterprising person would offer bolt-on kits for popular tractor models.
OH....BTW....not sure if you travel on the roadways.....but, if so, you may want to get a slow-moving-vehicle bracket (bracket and "pocket") so you can mount same on your tool box. They have the bracket at farm stores.
Thanks ! I was surprised that no aftermarket box mounts were available.
Have no intention to travel on the road, but I think I will just make a magnetic bracket for the signal.
/ 3005 tool box done today. #12
Chain carrier is a nice addition :thumbsup: I usually wrap a chain on the lower 3pt links when I need one.
Are those Rigid LED lights? How do you like them?
/ 3005 tool box done today. #13
$20 in steel
Good job, looks great.
The rigid lights are great, very bright and I also posted a short review of them. I did buy a better "tractor quality" switch. Other than that they are top notch.
Very nice work. Does your top-link hit when the 3PH is raised all the way?
1/2 Clearence from the chain hook holder, I measured for the box and mounted the ring in the middle not thinking, well got lucky it doesn't hit.
John Deere 925 Cultimulcher (A66408)
John Deere 925...
2015 Toyota RAV4 SUV (A61574)
2015 Toyota RAV4...
2017 INTERNATIONAL LF687 DAYCAB (A65643)
2017 INTERNATIONAL...
2022 EZ-GO ELITE...
2007 Nissan Frontier Ext. Cab Pickup Truck (A64556)
2007 Nissan...
Farm & Home 40-gallon UTV Sprayer (A66408)
Farm & Home...
