sandman2234
Super Member
- Joined
- Dec 4, 2005
- Messages
- 6,780
- Location
- Jacksonville, Florida
- Tractor
- JD2555 and a few Allis Chalmers and now one Kubota
The shaft that holds the lift arms and goes thru the bottom of the rear case is leaking on my JD2555. I picked up a couple of seals and extra washers a while back in anticipation of the repair. Now it has gotten worse and needs to be fixed. The seals I was sold are purple in color and look like a plastic seal for lack of a better way of discribing it. The one on the tractor is a metal faced seal. Since the lift arms ride right up against that seal, I would think that the plastic looking seals are wrong and should have a metal backing on them.
After spending WAY TOO MUCH TIME trying to find the shaft and seals on JD's website, I finally decided to do the smart thing and ask you guys what the name of the shaft and those seals are called. I called a friend, who suggested it was a Rockshaft, but that is higher up, with arms on it, that lift the arms via adjustable rods.
Anyone know the correct name of the shaft that is at the bottom that the lift arms ride on, and where to find it on JD's website?
Thanks, David from jax
