Big tree removal
   / Big tree removal #1
galaxie428
Gold Member
Rushville, IN
Bobcat CT230
I thought I would post some pics of my latest project because I was impressed with my CT230 and Woods BH80-X hoe. I wasn't really sure it was going to be up to the task because this is by far the biggest tree I have attempted to take down. But, I thought if I could get the roots all around the tree broke, I could pull it down with my truck since most of the weight is to the west side where I wanted it to fall anyway. The other side of the tree had broken off before we bought the place, I still hated to take it down but it was kind of ugly with only half of the tree being there. I have planted plenty to replace it anyway.
It took me about 2.5 hours of digging to get it to the point I was ready to try to pull it down. That is a lot less time than I had figured it would take.
I measure the tree once I had it downed and it is around 85' tall and had a circumference at a couple feet up from the base was 9'9". I had dug down around 5-6' all around the tree and had several straps, cables and chains to get me far enough away from the tree when I tried to pull it over.
Now once I get it cut up, I don't know what I will do with the root ball because I am certain that my loader will not lift it. I may have to see if I can drag it back to the burn pile. I think I can knock a good portion of the dirt off it with the hoe so that should help.
I am very impressed with some of the jobs my tractor and hoe have been able to handle. I think it has been by far one of the best things I have ever bought. I certainly would do it all over again!
   / Big tree removal #2
:shocked:
I'm guessing you didn't find that technique in the manual.
That sure was one heck of a tree to take down with a cut wow.:confused2:
   / Big tree removal #4
Well, I know it's alot easier dealing with the stump/root ball while it's attached to the rest of the tree, to use as a lever.
You would be there for 2 days trying to get that stump out of the ground, if you cut it down with a saw.
Did you need that space where the stump would of been?
I had to do one like that where I was constructing a driveway.
JB
   / Big tree removal #5
Man, that's some ambitious work.
But I am really having a hard time seeing the "ugly". That was a still a beautiful tree, man. A serious piece of wind-break still, too.
Just cut off the broken side nice and flush and it would be fine.... no? If it was a hardwood you could get a lot of energy or use out of the downed wood at least, vs a conifer. Ah well, could still cut some nice planks.
   / Big tree removal
I would much rather saw a tree up on the ground, it is just easier for me. I am sure others have a different opinion. I have cut trees down before and then tried to get the root ball out and yes, it takes a wole lot longer.
The stump would have been in the front yard so I didn't really want to leave it there and have to mow around it. I used a stump grinder on a few I cut down when we bought the place and it seems like every year I end up putting more dirt over them where they keep decaying. So I typically try to remove the stump if possible.
The pic was not at an angle where you could see how much the broken off part stuck out the east side. It is in kind of a Y shape. The part still attached hangs out over the west a ways. I never like to take down trees that are still living but it just did not look good. I have taken down a few dead trees on the property but I have planted more than I have taken down.
   / Big tree removal #7
Good job!!!
I take trees down like that fairly often with my full sized backhoe. Once I get enough dirt out of the way, I can push them over just about exactly where I want them with the hoe stick. I was wondering if you had enough weight to do that? and how much leverage you can get?
Once I decided on the side that the tree will fall, I dig that side first and try to get under the root ball as I go to the sides. That really helps in getting it to go the direction that I'm wanting it to go. I've never had a surprise doing this, but my dad has had a few go off to the side instead of the direction he's pushing. He's taken out thousands of trees this way, just like I have, so I really don't understand why this happens to him and not me.
I've also found that no matter how much I like a tree, once it's gone, I never miss it and sometimes struggle to even remember it once it's gone.
Eddie
   / Big tree removal #8
it's fun to take down big trees with little tractors. :D
it can get kind of scary digging the last part though.
   / Big tree removal
Here is a pic of me in the "hole" with the dogs today. I have been working on getting it cut up but it started raining on me. My helper has decided she is not going to come outside today so I guess it is up to me.
I think my hoe only goes up to about 7' high and I am not sure I could have gotten close enough to the tree to make much of a difference and like you said, probably not enough power/weight anyway.
   / Big tree removal #10
it took me a couple of hours with a garden hose, shovel, etc, on that pic i posted, but you would be surprised how much dirt will come out of that root wad and go back into the hole. :thumbsup:
2016 Chevrolet Traverse SUV (A59231)
2016 Chevrolet...
Toro Zero Turn Lawn Mower (A56859)
Toro Zero Turn...
Ford 8510 (A53317)
Ford 8510 (A53317)
2005 Peterbilt 387 with Wet Kit (A56438)
2005 Peterbilt 387...
48ft all aluminum feather light wedge trailer (A56438)
48ft all aluminum...
2024 PRO FABRICATION RTM-5.2K-Y REEL TRAILER (A59905)
2024 PRO...
