Just Little Bites ...
/ Just Little Bites ... #21
You're gonna be surprised how fast that fills-in with gravel from upstream. You can't drive much in that loose gravel either.
Bucket can scoop out loose gravel! :cool:
About 1/2 a mile from the spring where this creek starts ...
It worked!
I got 350 gallons pumped out to water my trees yesterday!
I got home late this morning, and put the BH back on, and went down to the creek again ... My thought is I want to make the creek crossing wider, the the water flow will be more spread out once it starts to flow, and hopefully not wash out this spring ...
I figure if I can push the whole bank back about 3'-4', and keep the same level of the creek crossing it will be a good afternoons worth of work!
It was nice T-shirt weather, eventually the clouds came in, it forecast to storm tomorrow ...
So I started digging! Widening the reservoir to get it to open up into the crossing better ...
There is a reason this area is called Rocky Hollow ... Fortunately none are big! (And I'm not using a shovel & wheelbarrow!)
Scoop it ever which way I can ... Just little bites at a time ...
Gotta build the ramp back out for the crossing, it needs to be more gradual to get the mower across ...
Got the ramp the way I like it, while I can go up it with this little tractor, I need it 3 times as wide for the mower ...
I added all the dark dirt today! 🤠 😁
Done for now ...
Yeah, that was at 17:40 ... We had a high of 76°!
But it won't last ... Not normal for here,, this time of year, local weather station is saying a few records were broken ...
This now at 02:45 it saying ... But I'm.leaving in a bit to go down near Houston, TX c
2014 CATERPILLAR 573C FELLER BUNCHER (A62129)
2014 CATERPILLAR...
2003 FREIGHTLINER FL70 DAY CAB (A60736)
2003 FREIGHTLINER...
ALLMAND LIGHT TOWER (A60736)
ALLMAND LIGHT...
2025 Polaris Ranger XP1000 (A60462)
2025 Polaris...
2023 FORD F750 CAB & CHASSIS (A57880)
2023 FORD F750 CAB...
(INOP) 2018 FORD EXPLORER (A59823)
(INOP) 2018 FORD...
