How to Jack up A tractor?
/ How to Jack up A tractor?
Please don't use concrete blocks for any vehicle support. People have died that way. They just aren't designed to support those type of concentrated loads and can crumble without warning.
Ok... I'll use lumber blocking only.....
I love having a loader and back hoe. Rotate bucket to raise front wheels... add jackstands. Raise rear wheels with backhoe stabs. That is so long as the engine is running...
I did plan to use the loader to lift the front.... but I don't have a backhoe, so it's going to require the jack.
When taking off the rear wheels make sure you have checked if they are loaded or not. If they are you need help or you may end up with the tire on top of you. Often they are loaded with a loader on the tractor.
No... they are not loaded.
But good thought to check them.
Thanks, Tim
/ How to Jack up A tractor? #25
Tim - I don't know where you are located but here in my community we have a Service company that comes out to you and services farm tractor tires...you might want to call around since usually these Tractor tire service companies are everywhere there are big tractors.
/ How to Jack up A tractor? #26
Those rear tires are really heavy and awkward to handle. Here's how I do it.
The tractor is a 1951 Minneapolis Moline BF that I've been restoring the past few years (I work slow).
The gantry is a $650 unit from Harbor Freight rated at 2000 lb.
Good luck and be careful out there:thumbsup:
I'll do some checking around, thanks for the suggestions. I do have to take either the tractor or the wheels to the tire dealer I found. He is a hour and 1/2 away but he has the original oem tires that came with my B2150 AND he has the best price.. AND he said he will not charge to mount them tires.
/ How to Jack up A tractor? #29
flusher,
That's a nice setup. Thanks for sharing the pics.
Tim
It's all about safety. I work alone. Don't want one of those rears to get away from me and do some grievous harm to my 70-year old body:).
Yes.. the older we get, the "smarter" we work.
I've gotten older... and hopefully a little smarter.
/ How to Jack up A tractor? #31
Those are interesting... what are those and where did they come from ?
The top is made from 4" channel. The center section is made from 4" x 6" tubing. The bottom is made from 1-1/4" bar stock, but you change this to suit your floor jack. All came from 'scrap' bin at work. Philip.
Nice work.....
/ How to Jack up A tractor? #33
Jackstands of the proper size are your best bet if you have them. The cup shape of the support saddle helps keep the vehicle in place better in case of side loads that can happen when working on a vehicle in the air. Wood blocks are far better than cinder blocks, but it's best toe screw or nail them together to keep anything from slipping as much as possible.
/ How to Jack up A tractor? #34
Haven't followed the thread whole thread - so this may be redundant - but I tend to use jack stands on some kind of dunnage to prevent sinking into the soil or marking the shed floor.
Cinder blocks are an absolute no-no.
Z.
/ How to Jack up A tractor? #35
The ole scrap bin from work!! :drool: How I miss that now that I'm retired!! :thumbsup:
I don't have any jackstands, so lumber is it.
I'll be working in my garage on the concrete slab.
/ How to Jack up A tractor? #39
Don White:
Good point Don. Reading back I could'nt figure why everybody hated concrete! Cinder block is much less dense and with the holes in the middle, not a good idea at all! I only use concrete as a backup. As you say a backup is common sense. Once I jack up, I slide and stack (flat) the blocks and a piece of 10x2 under the axel. If the jack fails the axel would drop right on to the backup. That way the load is spread over at least a square foot. Trouble with axle stands and jacks is the small footing area. You are dependent on the ground beneath.
In more years than I care to mention of jacking up vehicles I've had instances where the rear axel ended up laying on the backup concrete. One time the vehicle rolled (should have put the foot brake on and locked the wheels better) and the jack twisted. The other time the asphalt sunk suddenly on one side of the axel stand. Best plan is never to get under with wheels off. Most times it isnt necessary.
/ How to Jack up A tractor? #40
We're kind of beating a dead horse here, but I think where people probably get into trouble with cinder blocks is when they are used "naked".
Without something else to spread the load, having an axle or frame member bear directly on a small portion of a cinder block is just a recipe for disaster.
With the load properly spread, a cinder block is probably capable of bearing a large load. With the load concentrated on a small area, not so much. The trick here is "properly spread".
Best approach is to just stay away from them. It's particularly important to discourage a first-time backyard mechanic from using cinder blocks.
I'll get off the soapbox now...
Z.
1999 JOHN DEERE 344H WHEEL LOADER (A63276)
1999 JOHN DEERE...
2014 John Deere 310SK 4x4 Extendahoe Loader Backhoe (A61572)
2014 John Deere...
2010 Deere 318D (A60462)
2010 Deere 318D...
CASE TV450B SKID STEER (A64279)
CASE TV450B SKID...
2021 TAKEUCHI TL12R2 SKID STEER (A64279)
2021 TAKEUCHI...
2006 PITTS 4 BOLSTER LOG TRAILER (A64276)
2006 PITTS 4...
