Post driver hookup Case jx95
/ Post driver hookup Case jx95 #1
dao4ccl
I have a Case JX95 that I want to hook up to my new Shaver HD12 post driver. The hydraulic into the driver is the usual quick coupler but, the return from the post driver is a 1" diameter hose. I was told it should dump in to the hydraulic tank on the tractor. The only opening I find is the fill plug at about 3/4". Any ideas where or how to hook up the return line to my tractor? I thought about plumbing into the 1" line that feeds the hydraulic filter or rigging up a hydraulic fluid dump tank that I would than plumb into a smaller sized port on the tractor (yet to find).
/ Post driver hookup Case jx95 #2
We have a HD-10, on some of the tractors we've used it on we just adapted down to 3/4 with standard metal pipe fittings. We have had no problems in doing this. I'll try to get you a picture tomorrow.
/ Post driver hookup Case jx95 #3
If you want to filter the return fluid from the past pounder, then tee it in before the filter.
/ Post driver hookup Case jx95 #4
I don't think you want it going thru the filter. My understanding of these post drivers is you need and unobstructed flow from the return in to the reservoir. The post is driven by the springs pulling the weight back down at high velocity. The hydraulics are used to raise the weight and tension the springs. When you let off the valve lever all of the fluid is quickly pushed out of the cylinder, any restriction in that flow will interfere with the springs pulling the weight down.
/ Post driver hookup Case jx95 #5
Everything going into the reservoir should be filtered. So if the tractor filter can not handle the return flow, then add an external filter that can flow the pounder GPM's. It can be mounted on the post pounder.
Excerpt:
Attach hydraulic
return hose (larger diameter, G20) to the
tractor return port.
Does the tractor have an input filter or a return filter, or both?
/ Post driver hookup Case jx95 #6
Return flow from Shaver post drivers MUST return directly to the reservior by means of a zero-pressure return. DO NOT attempt to return the oil to a filter (which would be nearly impossible on a JX) and DO NOT install an external return filter. Rig a return fitting into the hydraulic oil fill, call your CaseIH dealer and ask for the location of the zero pressure return on your tractor (there should be an ASIST bulletin covering that), or call Shaver and ask how to connect your specific tractor model. If you prefer to use a quick coupler of some kind on the return, be certain that it will flow more oil than a 1/2" ISO standard coupler which is not quite adequate for the job. 3/4" unrestricted fittings will work.
Been there, done that on several Shaver installations.
Dont re-invent the wheel or take advice from folks that wouldn't know a post driver if it hit them on the head.
/ Post driver hookup Case jx95 #7
Excerpt:
Attach hydraulic
The peak return flow from a post pounder is huge -- over a quart per second average with even one of the HD8 Shavers -- perhaps a gallon per second at terminal fall velocity [end of fall]. The HD 12 will be several times as much because the much heavier drive head and helper springs requires a proportionately bigger cyl to lift. The restriction caused by even a large filter at well over 60GPM peak flow would seriously hamper the driver by slowing its fall. Dont obstruct the return from the driver at all. Youll be happy you didnt.
larry
/ Post driver hookup Case jx95 #8
Not to beat a dead horse, but my tractor has a filter on the suction side of the pump. If you dump fluid into that large pipe, you will likely cause surging of the input pressure to the main pump as suddenly the suction side will be under pressure rather than suction. That's if you don't blow up the filter that was never designed for pressure. I've never understood why anyone would filter a return-to-reservoir line anyhow. The reservoir is the most likely source of contamination, and filtering the suction side ensures reservoir debris are stopped before going to the main pump.
Okay, this dead horse is also properly beaten.;)
/ Post driver hookup Case jx95 #9
The tech at Shaver said the fluid flowing out the cyl on the return stroke is about 16 oz/1 pint per stroke. The return fluid into the 1in hose is flowing out in cycles, not continuous. Strokes per minute is variable according to the operator.
I believe the cyl is about a 1 in cyl, maybe .5 shaft/rod that would give it 1/4 in walls
I really don't think the GPM's figures some of you quoted is valid.
Shaver said you could run a filter if it posed no or low restriction.
If you want to try a filter, put a gage in the return hose and you will see exactly what is happening. You should be looking for a pressure less than 50 psi on the return hose.
Your reservoir is supposed to be clean and a lot of hyd system draw out of the reservoir directly.
Hydrostatic systems especially like clean fluid and therefore use an input filter. So it appears there is no one answer for hyd filters. They each have a place and use.
Just about all the engine driven log splitters have a return filter .
On some of the Shaver hyd trailer pkg, the pump is inside the tank, and the tank should be clean, so a return filter is about the only option.
/ Post driver hookup Case jx95 #10
larry
16 oz of fluid into a 1 in hose is going to produce how many GPM at maybe 7 to 10 cycles per minute.
You reckon that valve will handle that volume?
/ Post driver hookup Case jx95 #11
Yes. The valve is sized for its function.
tttt:) Bear with me here ... The HD 8 takes about a quart of fluid raising the driver 48". That quart is expelled back to sump in about 0.5 second if the driver falls without resistance ... and there are helper springs used to make it fall even quicker. Right there thats more than 30GPM average flow during descent. That isnt terribly much, but the peak flow, when it is going its fastest just before it strikes, will be around twice that [>60GPM]. A HD 12 will be at least twice again that much. There will be tens of PSI across even a large filter. It will slow the descent, compromising the strike, and in extreme cases will blow the filter.
larry
/ Post driver hookup Case jx95 #12
The effective displacement of the cylinder used on the HD-12 is about 20 cu.in. based on a 3/4 inch rod and 46 inch stroke as determined by my perusal of the description of the rod, cylinder and nuts attaching the rod to the machine as shown in the owner's and parts manuals. Cylinder bore does not enter into the equation as there is no full-diameter piston involved. A pint of fluid equals a little over 28 cu.in.
Larry is probably correct in estimating the flow rate at nearly a quart per second, I'd guess. But J_J's statement that only a pint of oil is involved seems accurate as well. We are talking about a small volume of oil leaving the cylinder in a very big hurry. It's no accident that the high pressure hose connecting the cylinder to the valve is either 5/8" or 3/4" hose. And it won't take much of a downstream restriction to blow the 1" return hose supplied by Shaver to pieces when the hammer drops. That I have seen first-hand.
Edit:
This post follows Larry's post #11 but was drafted prior to my seeing or reading it. I think we are both saying essentially the same thing.
/ Post driver hookup Case jx95 #13
Edit:
Yeah, I was wrong on the volume. Its about 1/2 what I said on the HD8 which has a 3/4 rod [I measured mine]. I would think theyd need more area to lift the heavier driver on the HD 12 tho:confused:. I dont know, but the specs would tend to indicate you would need more guts lifting ... and the flow requirements also suggest that a bigger rod area is being displaced. Also, too big a rod on a small driver would displace more fluid than necessary and thereby damp the fall of the comparatively lightweight ram. This all points to an error in the HD12 spec you are looking at. ... Either way, as weve said, there is a very high flow rate duing the latter stage of a fall and a filter is in the way.
Post Driver Specifications
/ Post driver hookup Case jx95 #14
THe HD10 and HD12 use the same cylinder, part #SM1026. Assembly instructions call out 1-1/16 " and 1-1/8" wrenches to install the lock and jam nuts on the end of the cylinder rod. Standard nuts of that sze would be normal for a 3/4" threaded shaft or bolt.
My bad, the hose connecting the cylinder to the valve is 1" hose in both cases.
The other thing to consider is the volume and flow of oil leaving the cylinder is ADDED to the volume of oil passing through the valve and back to sump when the driver is conected to a functioning open center hydraulic system which the subject tractor has. At 15 GPM, that is another quart per second.
/ Post driver hookup Case jx95 #15
dao4ccl,
Do you have the other cyl for tilt? If so, then you are probably using the PB port. If the post pounder is in series with the 3pt, then the main flow is flowing through the series circuit, and the only fluid flowing out the OUT/return hose is the expended fluid.
Are you plugging into the remote valve if you have them?
Can you give us the hyd flow path on your tractor from pump to tank, including the post pounder.
How many full strokes can you get out of the pounder in one minute?
Someone else mentioned that they ran the 1 in return hose into a 3/4 fitting and then to the return circuit and everything worked OK.
When you get it all connected, would you do a short test by putting the return hose in a bucket and cycling the post pounder several times and let us know the amount and volume of fluid coming out that 1 in hose.
If you put a 1 in tee with gage in the return hose, that would tell the whole story. Just curious
I would be curious to see if the post pounder would pound a railroad beam with flat bottom into the ground. Some people seem to dig a small hole first or put a point on the wood beam.
I did watch the video.
/ Post driver hookup Case jx95 #16
dao4ccl,
Can you give us the hyd flow path from pump to tank.
I have an HD10 & it will drive a RR tie with a square bottom in clay with no problem.
Thank you all for your responses and input. I attached the Case manufacturer suggestions which we have not followed yet and may not. We were able to order a metric threaded hydraulic fitting to fit the fill hole and a few other fittings to reduce the 1" hose down. The pounder is working well, about 15 posts done. The fittings do reduce the inside diameter at the fill hole to about 1/2" which, I do not like. The plan is to use a short threaded pipe at the connection to the fill hole as it will have a larger internal diameter. Took about 30 sec to drive a post about 3' in the ground no rocks, and about 2 min for a post that hit some rocks. Certainly better than by hand:) Now I need to buy more posts. Will post a few pics of stuff later.
  • JX95hookup.pdf
/ Post driver hookup Case jx95 #18
dao4ccl,
I am still curious about the pressure on the return hose. If you get a chance, would you put a hyd gage on the return hose at the filler cap and let us know the pressure, whether the pressure builds and peaks or averages out.
Which fluid is flowing into the return hose, is it total valve fluid, or is it only the cyl expended fluid?
The number of strokes per minute may vary the return pressure.
Thanks
2014 International WorkStar 7500 T/A Leach 2RIII 25CuYd Rear Loader Garbage Truck (A61573)
2014 International...
UNUSED IREV HIGH-END 2 WHEEL ELECTRIC VEHICLE (A64281)
UNUSED IREV...
2017 Hyundai Santa Fe AWD SUV (A61574)
2017 Hyundai Santa...
(2) UNUSED 15-19.5 TIRES W/ 6 LUG RIMS (A64280)
(2) UNUSED 15-19.5...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC-55 55ft Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
2005 Trail-Eze TE70HT53 42 Ton Hydratail T/A Drop Deck Trailer (A61573)
2005 Trail-Eze...
