Mounted a tool box
/ Mounted a tool box #1
Bob77064
Elite Member
KY @ TN line
2011 LS R3039
This is where the right step was.
/ Mounted a tool box #2
Plastic or metal tool box?
Will the location hamper any repairs/limbs & branches etc. from hitting box ight cause damage.
/ Mounted a tool box #4
I like the idea. What method are you implementing in the mounting? You stated earlier that if things didn't work out, you could always remove it and replace the former step.
The step is mounted by three bolts. The nuts are already welded to the tractor. With the step removed I used longer bolts to mount the tool box after drilling holes in it.
Here are pictures of the left step and the bolts holding the tool box on the right side.
:thumbsup:I think that it will work nice for you! But I think you should Paint it!
That may be the next step, I need to get some of the tractor paint.
/ Mounted a tool box #10
Bob77064 , Great move! I mounted a tool box on my Mahindra in the same place. Works great and its been there for over 1000 hours of use now! My tool box came off an old NH hay baler that i bought for parts, Used almost everything from the old pile of scrap. The box from the bailer fit perfectly in the given space, the cover overlaps the sides of the box and its mounted so the cover opens away from the tractor. The brush actually close it instead of opening it. If you zoom on the picture you can see it better. I'll try to get another pic tomorrow. Bob, just noticed you have only one hammer in there, and its small, how come? No vice grips wheres the wire? . . .Ha HA! ! ! . . . John
THREE POINT ATTACHMENT (A58214)
THREE POINT...
2020 Deere 50G (A53317)
2020 Deere 50G...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2008 DOOSAN G25 GENERATOR (A60736)
2008 DOOSAN G25...
PALLET OF 12IRON GATES (A58214)
PALLET OF 12IRON...
2014 FREIGHTLINER CASCADIA (A60736)
2014 FREIGHTLINER...
