Drill DR.
/ Drill DR. #1
okclumberjack
Member
are theses drill bit sharpners any good, will use non-commercially, just to sharpen 20-30 bits a year???
/ Drill DR. #2
I honestly don't know. Never tried one.
My dad sharpened his bits on a bench grinder. No jig, nothing. Seemed to be able to do it pretty well. As for me, I don't bother. I buy new bits when I need them. I don't buy the ones at the box stores. Good bits don't come in blister packages. ;) I get mine from an industrial supply.
/ Drill DR. #4
Got one for Christmas maybe 7-8 years ago. Works great for me, and probaby sharpen about that many on a year on it. Nice for touching up.
/ Drill DR. #5
I love mine. The grinding wheel is diamond, so the finish is so smooth and perfect the bits cut as good as, or better than, new.
/ Drill DR. #6
The DD works OK. I've used one for about a year.
/ Drill DR. #7
Will the DD sharpen split point bits?
/ Drill DR. #9
Certain models sharpen split points as well as turning ordinary drill bits into split points. I think mine is the 750, and sometimes I love it, sometimes I don't. I am personally better using a bench grinder, even the real little bits. I mostly use the DD for getting the nice angles, then try it out, then head to the grinder and make it actually cut.
/ Drill DR. #10
Mine will do split point bits.
And i LOVE my DD.
Mind you...you will never get more fighting going on in this site as you will by mentioning
1. Drill doctors
2. gold
3. Politics
4.Best Tractor
and in that order :laughing: :laughing: :laughing:
/ Drill DR. #11
And i LOVE my DD.
1. Drill doctors
2. gold
3. Politics
4.Best Tractor
You forgot best chainsaw! :D
/ Drill DR. #18
I recommend the DD. I also suggest that if you do get one, keep after the bits. If you give a bit a good workout...... touch it up before you put it back in the index. It takes a little practice to get the feel for it. Keep em cool!
/ Drill DR. #20
I got in the habit of inserting the drill bit upside down in the drill index when i felt it wasnt cutting the best it could. After i had 4-6 of them upside down, i bring out the DD and sharpen those up.
Has been working great.
Ingersoll Rand Air Compressor (A61166)
Ingersoll Rand Air...
2016 Ford F-550 4x4 Mason Dump Truck (A61568)
2016 Ford F-550...
iDrive TDS-2010H...
2016 WEILER P385A ASPHALT PAVER (A62129)
2016 WEILER P385A...
2022 John Deere Z930R Zero Turn (A63116)
2022 John Deere...
Four (4) R207782 John Deere Wheel Weights (A63116)
Four (4) R207782...
